question
    question
    is the official download page down for some reason ? i can get to the official page but i cannot download the new version. keep getting not found error.
    try this link which is official DVDFab website download page
    I just downlaoded from it so it does work
      i just tryed that keep getting not found
        [1].exe
        this is what i keep getting.
          check and make sure your firewall/antivirus is not blocking the website as the link I supplied works so it is a problem on your end
            got it fixed !! thank you!
