dvd fails to burn
    dvd fails to burn
    Hello,
    If I am posting in the wrong area I am sorry.
    I have been haveing problems with the last few movies I attempt to burn. I'll run throught he whole dvd process.
    Copy succesfull
    Insert writable disk.
    I'll insert a blank disk, DVD Fab will run
    formmatting disk is displayed. this runs like 10 - 15 minutes.
    Then stops running and a window pops up that says "failed to Burn" No message number to refer to.
    2009-10-20 16:31:20 ---- ******************** Log session stop 20-Oct 16:31:20.859 PID 3512********************
    2009-10-20 16:31:16 Info Disc ejected by user while parsing.
    2009-10-20 16:31:14 Info Parsing disc ...
    2009-10-20 15:57:56 Error WRITE FAILED: Can't find write strategy at sector 16
    2009-10-20 15:57:54 Error Write error at 0 (16) - Code 05 30 06 [Illegal request, Cannot format medium, Incompatible medium]
    2009-10-20 15:57:54 Info Write started 1435200 sectors to write
    2009-10-20 15:57:54 Info Init success: DVD+RW
    2009-10-20 15:57:54 Info Writing speed requested x0.5, effective x0.5
    2009-10-20 15:57:54 Info Format failed, trying to continue...
    2009-10-20 15:37:34 Info Format start
    2009-10-20 15:37:34 Info Available write speed:
    2009-10-20 15:37:34 Info Media ID: RITEK-F16-01
    2009-10-20 15:37:34 Info Media type: DVD+RW
    2009-10-20 15:37:33 Info Ultra DMA mode 2 (ATA33)
    2009-10-20 15:37:33 Info Scanned files #8, folder #2 - total size 2938181632 b. (2.74 Gb.)
    2009-10-20 15:37:33 Info Inserted media type : DVD+RW
    2009-10-20 15:37:33 Info Write started
    2009-10-20 15:37:29 Info Writable disc DVD+RW inserted. Ready to write
    2009-10-20 15:37:17 Info Parsing disc ...
    2009-10-20 15:32:25 Info Disc (DVD-ROM) not emtpy.
    2009-10-20 15:32:23 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2009-10-20 15:32:23 Info Drive has IDE-ATAPI physical interface
    2009-10-20 15:32:23 Info New Drive selected : 0:1:0 - ATAPI iHAP322 8 UL17 [E] (Ide)
    2009-10-20 15:31:43 Info Current Drive selected : 0:0:0 - HL-DT-ST CD-RW GCE-8525B 1.01 [D] (Ide)
    2009-10-20 15:31:43 Info Using Advanced SPTI interface
    2009-10-20 15:31:43 Info System default language : English (United States)
    2009-10-20 15:31:43 Info User default language : English (United States)
    2009-10-20 15:31:43 Info DLL Version : 4.0.4.462
    2009-10-20 15:31:43 Info DLL : C:\Program Files\DVDFab 6\vso_hwe.dll
    2009-10-20 15:31:43 Info Version : 6, 0, 7, 0
    2009-10-20 15:31:43 Info ExeName : C:\Program Files\DVDFab 6\DVDFab.exe
    2009-10-20 15:31:43 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
    2009-10-20 15:31:43 ---- ******************** Log session start 20-Oct 15:31:43.968 PID 3512********************
    11:57:09: Analyzing of DVD started
    11:57:11: Analyzing of DVD completed successfully
    11:57:11: Copy process started
    12:01:52: Copy process completed successfully
    12:16:22: Burn DVD folder (C:\Documents and Settings\Bob\My Documents\DVDFab\Temp\FullDisc\YES_MAN\) started
    18:34:11: Task_2 failed! Error=122
    15:32:24: Analyzing of DVD started
    15:32:24: Analyzing of DVD completed successfully
    15:32:24: Copy process started
    15:36:04: Copy process completed successfully
    15:37:33: Burn DVD folder (C:\Documents and Settings\Bob\My Documents\DVDFab\Temp\FullDisc\DVDVOLUME\) started
    16:31:00: Task_2 failed! Error=122
    I thought maybe I got some bad disks, I went out and bought a different brand of disks from a different store. Same problem.
    Could my burner be bad?
    Please help
    Thank You.
    I am not familiar with the disc you are using but this is strange................
    I have never seen this before. Do you have any disc that are not RW to try.?
      what do you mean RW?
        Your log says you are using DVD+RW.
        Do you have a DVD+ or DVD- to use?
          I'll go out and buy some tommorrow.
