Currupt Set up files
    Question, Since updating to Ver 7.082 I haven't been able to upgrade. Keep getting error when starting update install "The Setup files are corrupted. Please obtain a new copy of software". Current version seems to be running fine. When I originally acquired DVDFab I had an original install sent to me should I remove software and reinstall?
    I would.
    I'd run the Fab uninstaller and D/L a fresh new installer and be certain to open and run as administrator.
    If you still have issues, run CCleaner...both the registry cleaner and sweep.
    You may want to just run CCleaner the first time around...your call on that one
      Thank you. That seemed to do the trick.
        You bet, glad to hear you're all set
