Help Needed
    Help Needed
    Hi Guys,
    Another stupid question from Old Stupid"!!
    How do I get to put a quote in message?? Please show me the way. I can't find a way to do it.
    Thanks in advance for any and all help.
    Originally posted by oldpacman View Post
    Hi Guys,
    In the lower right corner of the post you want to quote there is, strangly enough, a button that says "Quote"
      Hi Guys,
      and to multi-quote you click the paper icon next to the one that says quote that has the + symbol for every post you want to quote and then on last post you just select quote and start the post
        Or you can do it "old fart" way - copy and paste, and add
        (QUOTE)
        in front and
        (/QUOTE)
        at the end of quoted text. Just replace ( ) with [ ]
        And you will have something likw this:
        Bla bla bla
        sigpic
          (QUOTE)
          in front and
          (/QUOTE)
          Or better yet you can just copy the text you want like IPopov50 mentioned and then highlight it and click what my attachment points to so you can add the quotes
