Advantages of burning with Imgburn versus VSO?
    What are the advantages & disadvantages of each of the burning options found in DVDFab (standard DVD version)
    VSO does not give you the option to set a burn speed for the media and DVD Burners you using and ImgBurn does. The VSO burn logs suck and do not give enough info to help with problems but ImgBurn logs give what is needed. VSO does not like cheap media and always fails to burn when using cheap Media but ImgBurn can use cheap media where VSO could not and if ImgBurn not able it will tell you in the logs if it cheap media as well.
    VSO some like using but others like ImgBurn and you would benifit more if you gave all options a try to see what you like to use. Here a link below on how to set up ImgBurn to work with DVDFab. Watch the youtube video
      Thank you. I will give it a try.
