Compatibility Issues
    I'm thinking about upgrading XP-PRO 32Bit to Windows 7 64Bit , total memory to 6 Gb . & add a Corsair Force 120 Gb SSD to my system .. What Compatibilities Issues can I expect for DVDFab Blu-ray Copy ?
    Shouldn't be too many based on those specs. Many people in the forum are using Windows 7 64 bit - myself included. Video cards will vary depending on whether you can use some of the Cuda support or not. Just a matter of playing with settings until you are happy.
      I moved your thread to General Chat...and no, I don't think it was "wrong" to post in the Blu-ray subforum,
      I just think this is a better fit and you'll be more visible here.
      What are running for a cpu?
      What video card?
      I'm asking not so much for compatibility issues, but more toward convenience and efficacy.
      If you're compressing and/or converting, you'll want a decent amount of horsepower.
      I'd hate to see you spend your hard-earned $ and be frustrated with the time it takes.
