Just started using Free DVD today. I can remove the protections from the movies. But I cannot figure out how to re-burn them onto another DVD when they are split up in the Video_TS folder? Also, when I go to play a clip of the movie, the picture is all jumbled. Im a mess. Help!
Free DVD program help
Guest
Originally posted by lars_7485 View PostJust started using Free DVD today. I can remove the protections from the movies. But I cannot figure out how to re-burn them onto another DVD when they are split up in the Video_TS folder? Also, when I go to play a clip of the movie, the picture is all jumbled. Im a mess. Help!
2- The free edition of DVDFAB does not compress.
3- The free edition of DVDFAB will only rip to your hard drive.
4- The movie is always ripped in 1gb segments or split up as you say.
You will have to use a separate software to compress if needed and to burn [imgburn] to a disc.
Now-- if you just started using it today as stated you should be using the full function 30 day trail which will handle the entire process. ???
