I have a problem. I bought this region 4 movie and I made a copy of it. I tried to watch it with my regular dvd player and it says "disc error." When I copied it I changed the settings (dvdfab) to region 4 and checked the remove region codes and now I cannot play my copy. What am I doing wrong?
Problem playing a dvd movie
Sounds like a PAL - NTSC issue
Is your player NTSC <----> PAL compatible?
Does the copy play in your pc?
If yes, that's it.
I doubt this has anything to do with the region coding.If it ain't broke, don't fix it!
The difference between PAL and NTSC is not just the region code. The frame rate, frame resolution and some of the carrier signals are different. It’s a completely different video format. There are ways to convert PAL to NTSC but Fab won’t do it.How to post the internal log
Originally posted by dragongirl2010 View PostIs there a good program that converts PAL to NTSC and vice versa?
