Another Dumb Question????
    I'm sure I should already know this but why do some movies save in DVDfab and others do not? I go to temp and fulldisc and the movies are there sometimes and other times they disappear. Is it my settings? Just curious what I should do to keep them from saving in there. Do they take up hard drive space that way.
    Tracy
    Yes they take up hard disk space that way.
    The 'delete temporary files when done' setting in 'General Settings' controls this and when Fab is shut down in normal fashion, the files are deleted. If the shutdown is caused by a crash or something else while fab is still running, the files are not deleted.
