Viewing Blu-ray from HDD
    Just a novice, trying to find best way to view blu-ray once they are copied to hdd.
    Seems some blu-rays have a single large file in stream that will play the entire movie, and others have multiple files that will only play as individuals. Any help with the best way to view blu-rays from hdd would be great…Thanks to all!
    TMT3 is a very recommended playback software.
    人生は贈り物であり、完全な喜びを経験する必要があります
      Besides the best player on the planet recommended by Blazkowicz, when playing BDs, do NOT play just the file(s), as in the m2ts files. This will cause you no end of issues if you do. Like most players won't recognize the HD audio stream if played by file. The best way is to play either by folder with ArcSoft TotalMedia Theatre, MPC-Home Cinema, etc. or create an ISO file and mount with DVDFab Virtual Drive and play that with ArcSoft, MPC, VLC, CyberLink PowerDVD, etc. The way I play mine is by folder in ArcSoft(as a paid player) and MPC-Home Cinema(free player), but some people like ISOs.
      SPECS
        Thanks for taking the time to help...I will try the ISO suggestion
