re-set DMA
    re-set DMA
    Filter Driver Load Order - ImgBurn v2.5.2.0
    Upper Device Filter: redbook
    Upper Class Filter: [None Found]
    Device: CD/DVD-ROM Device
    Lower Class Filter: [None Found]
    Lower Device Filter: imapi
    Filter Name: redbook
    File Name: C:\WINDOWS\system32\DRIVERS\redbook.sys
    File Version: 5.1.2600.5512 (xpsp.080413-2108)
    File Description: Redbook Audio Filter Driver
    Product Name: Microsoft® Windows® Operating System
    Product Version: 5.1.2600.5512
    Company Name: Microsoft Corporation
    Copyright: © Microsoft Corporation. All rights reserved.
    Filter Name: imapi
    File Name: C:\WINDOWS\system32\DRIVERS\imapi.sys
    File Description: IMAPI Kernel Driver
    Having trouble re-setting DMA again with dvdfab! Went back to old post and added Imgburn information! After re-set and restart PC, still get I/O device (volume lock-access denied, and the other access denied for the I/O device! starting to back-up Just Wright and Date Nite! Will see if DMA will re-set! I will be back in about 30min's
    Do you have Service Pack 3 installed?
      re-set DMA
      I 20:16:02 ImgBurn Version 2.5.2.0 started!
      I 20:16:02 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
      I 20:16:02 Total Physical Memory: 1,046,524 KB - Available: 547,664 KB
      I 20:16:02 Initialising SPTI...
      I 20:16:02 Searching for SCSI / ATAPI devices...
      I 20:16:02 -> Drive 1 - Info: PLEXTOR DVDR PX-870A 1.05 (D (ATA)
      I 20:16:02 Found 1 DVD±RW/RAM!
      I 20:16:04 Operation Started!
      I 20:16:04 Building Image Tree...
      I 20:16:04 Checking Directory Depth...
      I 20:16:04 Calculating Totals...
      I 20:16:04 Preparing Image...
      I 20:16:04 Checking Path Length...
      I 20:16:04 Contents: 9 Files, 2 Folders
      I 20:16:05 Content Type: DVD Video
      I 20:16:05 Data Type: MODE1/2048
      I 20:16:05 File System(s): ISO9660, UDF (1.02)
      I 20:16:05 Volume Label: JUST_WRIGHT
      I 20:16:05 IFO/BUP 32K Padding: Enabled
      I 20:16:05 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
      I 20:16:05 TV System: NTSC
      I 20:16:05 Size: 4,508,928,000 bytes
      I 20:16:05 Sectors: 2,201,625
      I 20:16:05 Image Size: 4,509,564,928 bytes
      I 20:16:05 Image Sectors: 2,201,936
      I 20:16:05 Operation Successfully Completed! - Duration: 00:00:00
      I 20:16:05 Operation Started!
      I 20:16:05 Source File: -==/\/[BUILD IMAGE]\/\==-
      I 20:16:05 Source File Sectors: 2,201,936 (MODE1/2048)
      I 20:16:05 Source File Size: 4,509,564,928 bytes
      I 20:16:05 Source File Volume Identifier: JUST_WRIGHT
      I 20:16:05 Source File Application Identifier: IMGBURN V2.5.2.0 - THE ULTIMATE IMAGE BURNER!
      I 20:16:05 Source File Implementation Identifier: ImgBurn
      I 20:16:05 Source File File System(s): ISO9660, UDF (1.02)
      I 20:16:05 Destination Device: [1:0:0] PLEXTOR DVDR PX-870A 1.05 (D (ATA)
      I 20:16:05 Destination Media Type: DVD-R (Disc ID: TYG02) (Speeds: 4x, 6x, 8x)
      I 20:16:05 Destination Media Sectors: 2,297,888
      I 20:16:05 Write Mode: DVD
      I 20:16:05 Write Type: DAO
      I 20:16:05 Write Speed: 8x
      I 20:16:05 Link Size: Auto
      I 20:16:05 Lock Volume: Yes
      I 20:16:05 Test Mode: No
      I 20:16:05 OPC: No
      I 20:16:05 BURN-Proof: Enabled
      W 20:16:10 DeviceIoControl(FSCTL_LOCK_VOLUME) Failed! - Reason: Access is denied.
      W 20:16:10 DeviceIoControl(FSCTL_DISMOUNT_VOLUME) Failed! - Reason: Access is denied.
      I 20:16:10 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
      I 20:16:11 Filling Buffer... (40 MB)
      I 20:16:12 Writing LeadIn...
      I 20:16:58 Writing Session 1 of 1... (1 Track, LBA: 0 - 2201935)
      I 20:16:58 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2201935)
      I 20:24:15 Synchronising Cache...
      I 20:24:36 Exporting Graph Data...
      I 20:24:36 Graph Data File: C:\Documents and Settings\Administrator\Application Data\ImgBurn\Graph Data Files\PLEXTOR_DVDR_PX-870A_1.05_MONDAY-SEPTEMBER-27-2010_8-16_PM_TYG02_8x.ibg
      I 20:24:36 Export Successfully Completed!
      I 20:24:36 Operation Successfully Completed! - Duration: 00:08:26
      I 20:24:36 Average Write Rate: 10,100 KB/s (7.3x) - Maximum Write Rate: 11,316 KB/s (8.2x)
      I 20:28:12 Close Request Acknowledged
      I 20:28:12 Closing Down...
      I 20:28:12 Shutting down SPTI...
      I 20:28:12 ImgBurn closed!
      After DMA re-set still get access denied, Do I need to post other logs from dvdfab?
        re-set DMA
        Gummigutta, as you can see it's in the log!
          Did the DVD burn correctly as it looks like ImgBurn still burned it
            re-set DMA
            Yes sir, AGJ, it still burns great copy's (Imgburn) and play great!
              re-set DMA
              Thank you very much AGJ!
                There is another program locking your volume. You should see this FAQ to find out the name of that other program.
                Problem: You get an I/O Error saying 'The Parameter is incorrect'. Answer: In the settings screen, change the 'Transfer Length' option to 'Manual' instead of 'Automatic' and put it on '32 KB' instead of '64 KB'.
                  re-set DMA
                  how do you get into device manager?
                    go to start on computer, then control panel. Once control panel opened click Performance and Maintenance. In that screen at bottom select System and then choose hardware, That will give you options and Device manager is one of them
                      re-set DMA
                      Thanks for the help guys, still working on the problem! Will be back tomarrow!
                        re-set DMA
                        Still can't re-set DMA, the frist web-site I tryed you had to have winace to download the Explorer software!, which I don't have! The other web-site, unlocker was tagged as a bad web-site, so I didn't try it!, but I did IRON MAN 2 yesterday and It still copyed and burned with Imgburn! So not going to worry about it! Thanks for all the help!
                          It's not a DMA issue, Gummi was right in post #8.
                          In the past this Lock Volume error was fixed when ImgBurn ver. 2500 was released. Try and backup to version 2500 to test or you can disable the Lock Volume within ImgBurn so you don't get the error but it's not recommended.
                            re-set DMA
                            W&B, Gummi is correct, but I tryed to D/L Process Explorer, but I don't have WINACE software and it wants me to pay for it! Don't have the cash right now! Or is there a way to do it without paying just to fix one problem! My pc does say that some other program is useing it through! Not very good at all with stuff like this! When I D/L an update like 8.0.1.7, it also tells me the same thing! I just D/L update twice!
                              This is what you downloaded?
                              It's free when I run it.
                              Find out what files, registry keys and other objects processes have open, which DLLs they have loaded, and more.
