This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
Is there anyway to remove subtitles from these types of files USING DVDfab?
Thanks
You can give DVDFab Video converter a try to see if you can remove the subs with that. Not sure if it works but does not hurt to try. The problem would be that you will convert the video again so might have more compression
