Dvd43
    Dvd43
    I was just wondering weather DVDFab would conflict with DVD43 when burning or removing protection.
    I have experienced these errors in the past with Any DVD, and wanted to make sure I would not have any similar errors.
    Thansk
    DVD43 plugin 1005............ No Conflict.
    DVD43..460 ........ Yes it will conflict if DVD43 is running.
    Fab will notify you to turn it off.
      Thansk
      Yes it will, as 2 decrypters running at the same time are going to "fight" as to who is going to work in decrypting the disc.
      CBR929
      Sorry Gruñón didn't see you again
        CBR929 I have had DVD43 plugin V1005 running in the background for months and have never had a problem.
        DVD43 V 460 yes there is a problem.
          Sorry didn't know thought 2 decrypters running was bad
          CBR929
            CBR929
            Normally you would be correct but DVD43 plugin V1005 seems to be the exception to the rule.
              Thansk
              Like already mentioned DVD43 will interfere with DVDFab. The DVD43 plug in that was mentioned only works for a certian DVD Copy program and does not interfere with any other DVD Programs including DVDFab.
              If you are looking for something that is like DVD43 and free give DVDFab Passkey a try as it free during Beta stage and has been in Beta stage for almost a year now.
              You can as well change DVD43 to not start when computer starts and that will not interfere with DVDFab but you will have to start it manually if you need to use it
