I notice that while copying a DVD to hard drive using DVDCopy there is an annoying little bug!
If your drive does not have enough space available, DVDFab will create the DVD folders on your HDD, then report to you that there is not enough space and aborts the copy leaving behind the empty folders !
If you go through 5 or 6 of your drives unsuccessfully looking for space, DVDFab creates and leaves behind empty folders of disappointment everywhere you tried.
When you finally find the space, DVDFab finally creates the folders and files and everything finishes up ok... Apart from all the trail of empty folders left behind.
Why can't the writers of this software check for space (and report insufficient) BEFORE creating the folders?
