DVD Fab 8022 (HD Decrypter) expiry problem
    since I have updated from version 8005 to 8022, every time when I try to use Blu-ray Copy, the program tells me that the trial version has expired and I should use free HD Decrypter. That's exactly what I want to do, but it doesn't work. The previous versions where ok. Any ideas?
    Please define "but it doesn't work." part. What exactly you trying to do and it doesn't work?
    sigpic
      m.rup
      Please update to the newest version http://forum.dvdfab.com/showthread.php?t=8688
      Hi IPopov50
        Hi IPopov50
        Hi my friend!!!!
        sigpic
          Originally posted by IPopov50 View Post
          Hi my friend!!!!
          Nice to see you posting again, I learn so much!!!!
            I was and I'm around, I just didn't post much because I couldn't offer much of a help except to say "welcome to the club" and offer them a hug.
            sigpic
              You are "VERY FAR FROM WRONG There" and yes I saw you around
              Enough chatting I dont want to get in trouble, again nice to see you posting.
              CBR929
                @IPopov50:
                Well, I start DVDFab. Then I select the last option in the list (sorry, my version is in german, I hope I can translate appropriate) which is free HD Decrypter, never expires, and run the program.
                Then, I insert a Blu-ray in my drive, DVDFab selects 'Blu-ray Copy Complete Disk' and analyzes the disk. After this, I select a target directory at my HDD, and then start the process. When doing so, a pop up window appears and tells me that the 'Blu-ray Copy' option has expired and I should use the free HD Decrypter. When I push the OK button, the pop up closes and in the status list a message appears 'process successfully finished' (as mentioned before, this is a translation by my own). Well, this was it, no ripping to my HDD. The earlier version (8005) worked well.
                Ps.: Now I have updated to 8024 (thanks CBR929), and at the first glance, nothing has changed, the message regarding the expiry pos up again. BUT: after pressing 'OK', the process is NOT finished successfully, but the ripping seems to start.
                Pps.: the language in the status list is messed up, the entries up to now are:
                The "Blu-ray Copy" option is expired. You are going to use "HD Decrypter"
                Analyzing started
                Analyzing completed successfully
                Kopiervorgang gestartet (<- german)
                Well, I will see if it is working now and hope the best.
                  m.rup
                  Hope its working for you now
                  Kopiervorgang gestartet (<- german) = Copying process started
                  CBR929
                    Ok, seems as if the process has been successful. But an old bug, which has been fixed in version 8005, has been reintroduced: When the progress bar reaches about 97%, it pops back to the begining and starts again. Also, the remaining time display jumps from 5 minutes to about 32 minutes, the elapsed time remains at 31 minutes, so the resulting total should be more than one hour. After about five minutes more, the process is finished (progress bar at about 20%), so the total time is reasonable 37 minutes. The BD is 'Cars', region B.
                      It seems worked "de facto" even with bugs. Remember, it should and will work only for copy. Decrypter would not compress the content. E.g. if you select BD25 1080i/p as an output for your BD50 content, HD Decrypter will show error.
                      sigpic
                        Yes, this is clear. I only mentioned this time/progress display thing because it is not occuring with my other blu-rays and has been disappeared in version 8005.
                          Hi m.rup,
                          We express our sincere sorry for inconvenience brought to you. Our developers are analyzing it and trying to fix this time/progress display issue appearing now and then.
                          And when you copy and burn DVDs with DVDFab, please disable all the other background tasks in your windows task manager. Since multitasking is therefore a reason for this time/progress display error.
                          ________
                          MEDICAL MARIJUANA
                            Hi sunny, thanks for the explanation, but could you explain a little bit more in detail which 'other background tasks' should be disabled in the task manager?
