Dual Layer disk with image burn
    I'm trying to burn Dual Layer disk with image burn since the VSO engine always "fails to burn" and now im having this layer break crap come up????? What is layer break and how to i get it to simply burn a dual layer dvd w/o having to go thru all this hassle and trouble?? IMGBURN gives me this screen full of jargon and cell this and cell that and that it doesn't recommend me to continue... ???? I just want to burn a dual layer dvd w/o any continuous issues. Please help!
    If you're burning a folder to a dual layer dvd, then you will have to select a layer break as it's not an iso(image) of the movie, so it won't remember the layer break position. Just select the best one, I think it gives you a colored star rating to find the best one.
    SPECS
      Highjack post and relevant reply moved to it own thread. To know why give this link a read
