ISO file to MP4? Which DVDFAB product do I need?
    I have an ISO file that's probably a Blu-Ray DVD. It's about 8GB.
    Looking to take this file and make it an MP4, AVI or something I can store on my harddrive.
    Which DVDFAB product would I use? I purchased the product but not all of the features.
    I don't want to buy something I don't need.
    Please let me know. Thanks.
    We would need to know the source and type of file.
    Unfortunately, "probably" isn't sufficient to recommend a specific software module, but more than likely, it will be Blu-ray Ripper.
    Could I ask why you want to convert it?
    Is it a size issue?...it's only 8 GB.
    Ultimately, how and what will you use for playback after it's on your hdd?
