HDD
    HDD
    When useing dvdfab copy and you want to copy a dvd to your hard drive and burn later, how is this done!, without haveing to burn and hit save buttom when finished?
    Your question is a bit confusing, but here's how to go about it.
    Open Fab > Target > select a location on your hdd. and rip the Source content
    Later when you decide to burn a disc,
    Insert your blank media in your burner,
    Select Write Data mode
    This will burn the files directly without re-ripping or otherwise processing the files.
    You need to have the correct blank disc, ie., SL or DL, because you can't compress or do anything else in Write Data mode.
    It's quick and direct
      hdd
      Thanks MaineMan, I understand now! This was just what I wanted to know! Sorry didn't explain the question that well!
        Nothing to be sorry about 88......I just wasn't sure.
        Glad it was the answer you were looking for.
