Latest Beta XVID or DIVX won't play on 360
    I have a bunch of movies I have backed up using DVDFab 6+ and Windows XP. I used XVID and MP3 and they all play on my XBOX 360. When I check them with GSPOT it says the Video Codec is XVID and the Audio Codec is 0x0055(MP3) ID'd as MPEG-1 Layer 3.
    Now when using the latest Beta of DVDFab 8 on Windows 7, when I backup my DVDs using either XVID or DIVX or they won't play on the 360. When I check the file format using GSPOT it says the codec is (_RGB) - BI_RGB Raw Bitmap.
    What is up with that? I tried it several times and it always comes out as that. Is it because I am trying to do it with Forced Sub Titles?
    Thanks for the help!
    Try 8.0.3.2, that issue has been corrected.
