dvdfab
    dvdfab
    can i rip a dvd and cut out the audio with DVD FAB
    Yes, you can....
      copying a dvd and taking out the sound
      will dvd fab remove the audio from a dvd if so how do i do it/
        Chose main move or customize mode and remove the check from the audio boxs
          Two threads with same question merged.
