dual layer dvd burning
    Optical Drives dual layer dvd burning
    hi,
    i use the free decrypter and use image burn to write to dvd.if i burn a normal dvd it works but a double layer dvd burning gives me an error while burning. i can shrink the size and it works but i want to copy into a double layer dvd.
    Hi hazepurple123
    Please post you logs the default location is:
    Please just attach your most resent burn log(s) and post right here.
    CBR929
      I think ImgBurn logs would be more useful, as the problem doesn't seem to be connected to decrypter. ImgBurn will burn even non-compliant images without write errors, though the result would be unplayable disc.
      Most probably the cause is in low-quality DL blanks, if the burner is verified to be OK.
      I had a similar problem with poor quality DL-blanks.
