A question about VOB files
    The new bluray to dvd converter is amazing.
    But I have a qustion,is it possible to create a VOB file with resolution above 1024x576 (and still be playable on as dvd)?Imagine that on the new converter.
    The DVD specification only allows for a resultion of 720x480.
      Yeah Complication is right. I believe its 720x480 for NTSC and 720x576 for PAL. From your original post, you said 1024x576 so I'm guessing you're in a PAL region?
      SPECS
        Yes Pal region.
          Like I said... 720x576 for PAL.
            Hehe nice. ^----^
            SPECS
