Burn problem
    Burn problem
    I just downloaded latest version and also imageburn since I was having burn problems. I thought this would help, so I started up DVDFab again. It went through the copying process, which was a success but when I put in blank to burn this error message came up:
    I 11:24:55 ImgBurn Version 2.5.2.0 started!
    I 11:24:55 Microsoft Windows Vista Home Premium Edition (6.0, Build 6002 : Service Pack 2)
    I 11:24:55 Total Physical Memory: 3,143,368 KB - Available: 1,679,252 KB
    I 11:24:55 Initialising SPTI...
    I 11:24:55 Searching for SCSI / ATAPI devices...
    I 11:24:55 -> Drive 1 - Info: MATSHITA BD-CMB UJ-120 1.04 (H (ATA)
    I 11:24:55 Found 1 BD-ROM/DVD±RW!
    I 11:24:56 Operation Started!
    I 11:24:56 Building Image Tree...
    I 11:24:56 Checking Directory Depth...
    I 11:24:56 Calculating Totals...
    I 11:24:56 Preparing Image...
    I 11:24:56 Checking Path Length...
    I 11:24:56 Contents: 77 Files, 2 Folders
    I 11:24:56 Content Type: DVD Video
    I 11:24:56 Data Type: MODE1/2048
    I 11:24:56 File System(s): ISO9660, UDF (1.02)
    I 11:24:56 Volume Label: GROWN_UPS
    I 11:24:56 IFO/BUP 32K Padding: Enabled
    I 11:24:56 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
    I 11:24:56 TV System: NTSC
    I 11:24:56 Size: 4,508,516,352 bytes
    I 11:24:56 Sectors: 2,201,424
    I 11:24:56 Image Size: 4,509,630,464 bytes
    I 11:24:56 Image Sectors: 2,201,968
    I 11:24:56 Operation Successfully Completed! - Duration: 00:00:00
    I 11:24:56 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 11:24:56 Source File Sectors: 2,201,968 (MODE1/2048)
    I 11:24:56 Source File Size: 4,509,630,464 bytes
    I 11:24:56 Source File Volume Identifier: GROWN_UPS
    I 11:24:56 Source File Application Identifier: IMGBURN V2.5.2.0 - THE ULTIMATE IMAGE BURNER!
    I 11:24:56 Source File Implementation Identifier: ImgBurn
    I 11:24:56 Source File File System(s): ISO9660, UDF (1.02)
    I 11:24:56 Destination Device: [1:0:0] MATSHITA BD-CMB UJ-120 1.04 (H (ATA)
    I 11:24:56 Destination Media Type: DVD-R (Disc ID: MCC 03RG20) (Speeds: 2x, 4x, 6x, 8x)
    I 11:24:56 Destination Media Sectors: 2,298,496
    I 11:24:56 Write Mode: DVD
    I 11:24:56 Write Type: DAO
    I 11:24:56 Write Speed: MAX
    I 11:24:56 Link Size: Auto
    I 11:24:56 Lock Volume: Yes
    I 11:24:56 Test Mode: No
    I 11:24:56 OPC: No
    I 11:24:56 BURN-Proof: Enabled
    I 11:24:56 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
    I 11:24:56 Filling Buffer... (40 MB)
    I 11:24:58 Writing LeadIn...
    W 11:25:04 Failed to Write Sectors 3712 - 3743 - Reason: Power Calibration Area Error
    W 11:25:04 Retrying (1 of 20)...
    W 11:25:04 Retry Failed - Reason: Power Calibration Area Error
    W 11:25:04 Retrying (2 of 20)...
    W 11:25:04 Retrying (3 of 20)...
    W 11:25:04 Retrying (4 of 20)...
    W 11:25:04 Retrying (5 of 20)...
    W 11:25:04 Retrying (6 of 20)...
    W 11:25:04 Retrying (7 of 20)...
    W 11:25:04 Retrying (8 of 20)...
    W 11:25:04 Retrying (9 of 20)...
    W 11:25:04 Retrying (10 of 20)...
    W 11:25:04 Retrying (11 of 20)...
    W 11:25:04 Retrying (12 of 20)...
    W 11:25:04 Retrying (13 of 20)...
    W 11:25:04 Retrying (14 of 20)...
    W 11:25:04 Retrying (15 of 20)...
    W 11:25:04 Retrying (16 of 20)...
    W 11:25:04 Retrying (17 of 20)...
    W 11:25:04 Retrying (18 of 20)...
    W 11:25:04 Retrying (19 of 20)...
    W 11:25:04 Retrying (20 of 20)...
    Can anyone have a solution to this problem for me? Thanks
    I got the same "Power Calibration" error twice.
    The fist time it was caused by a very bad blanks (oh well). But the second time, it was a slowly dying burner.
    Check your blanks, try with other brands and RWs... hopefully it's not the burner problem.
      The MATSHITA BD-CMB drive is known to be problematic and combined with you trying to burn at max speed is a guarantee of problems.
      Slow your burn speed down to 4X and think about getting an external burner.
        Thanks, I appreciate the quick responses. I was worried that the burner might be the problem.
