blue ray burning
    blue ray burning
    After I burn a copy of the blue ray I am getting a second sound track narrating the movie. Is this because I haven't bought the dvdfab software and I am in trial mode or am I doing something wrong? I selected blue ray copy- main movie- I burned it to a file and not to another disc. thanks for your help
    Firstly, it has nothing to do with the 30-day, free trial. The trial "version" is the same software as the retail product and has full functionality.
    The only difference is that if it is not activated within 30 days, it reverts to the freeware version.
    So you ripped the BD files to a hdd.
    What software player are you using for playback?
    Recommend Media Player Classic.
    It's freeware and an excellent player, plus it will give you plenty of info.
    Most likely, you did not deselect the narrative audio stream when you ripped it. Multiple streams are not a problem when playing back with MPC as you can select the appropriate stream, but if you don't want it, just deselect it.
    Take a look at this screenshot of Avatar.
    The deselected audio streams aren't actually narratives, but you get the idea.
      thanks
      Yes windows media classic worked great. Now my next issue is getting my ps3 media server to recognize my computer to stream the movies.
