I've got an NVidia GeForce 8800 GT video card and want to optimize DVDFab's use of it. I'm running DVD Copy 8.0.3.2. In the A/V section I'm not getting much in terms of non-software support.
How can I enable CUDA and other non-software options?
I've searched forum and help file, please forgive if I missed the answer.
Codec Information
Graphics Chipset : NVIDIA GeForce 8800 GT
Supported Video Codecs : DXVA_MODE_H264
CoreAVC : cannot be detected
Here are my current settings, and the errors I see when I try to change them:
Video Decoder
H.264 = DXVA
* When I select the CUDA option I get an error, "CUDA H.264 decoder cannot be supported by your graphics card."
* When I select CoreAVC H.264 I get an error, "CoreAVC H.264 decoder cannot be detected."
VC1 = Software. When I select either DXVA or CUDA I get the error, "...decoder cannot be supported by your graphics card."
MPEG = Software.
Video Encoder
H.264 = Software
* When I select Software+CUDA I get an error, "CUDA H.264 decoder cannot be supported by your graphics card."
Also, where can I find more information about what VC1, CoreAVC, and DXVA are? I've googled the terms I'm just looking for help in knowing which I should try to get working, when is which best. I hope that makes sense. I haven't done anything with BluRay yet, most of what I use DVDfab for is to backup my home dvd library (which I then use PgcEdit to fine tune how I want that backup to play).
My vid card is 512 MB; drivers are nv4_disp (6.14.11.6932 - nVIDIA ForceWare 69.32). QuadQ6600 @ 2.4GHz, 4GB RAM, Win XP SP3.
Codec Information
Video Decoder
H.264 = DXVA
MPEG = Software.
Video Encoder
H.264 = Software
