Shrinkung Media
    Other Shrinkung Media
    I have alot of shows that I would like to burn to DVD. I've tried Nero but I can only get two episodes per disc @ a time. I've tried making a data dvd but that hasn't worked either. I was wondering if dvdfab can be used for that. If not what programs would you suggest?
    Give DVDFab DVD Copy a try as it has 30 day free trial for full version before it reverts to the free version. DVDFab can do that depending on what the DVD source is
      Nero User
      If your talking about AVI files and you want to convert them to DVD Format then Nero works. You didn't mention how long the episodes are but you can always have Nero write the converted files to your HDD and then shrink the DVD to fit on a 4.7 Gb Blank using DVDFab. I think the longest I ever put on a blank dvd using Nero was around 2h 45min or so.
