Encore un autre beug sur un autre DVD
    1m 13.63s: ------------------ convert work begin(1/1) ------------------
    1m 13.64s: start process
    1m 13.65s: info: create config(dvdpassthrough)
    1m 13.66s: info: crop value after clone: left = 0 right= 0 top=0 bottom=0 enable=0 mode=0
    1m 13.66s: info: use profile(MKV Passthrough)
    1m 13.66s: info: dvd playlist(1),angle(0),chapter(1->12)
    1m 13.66s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
    1m 15.74s: info: stream input@ Video(480)[codec(mpeg2video) size(720*576) fps(25/1) interlace(1) duration(0)sec opcode(copy)]
    1m 15.74s: info: stream output Video(480)[codec(mpeg2video) size(720*576) fps(25/1) interlace(1) bitrate(0) duration(0)sec]
    1m 15.75s: info: stream input@ Audio(128)[codec(ac3) channels(2) sample(48000) bitrate(448000) bitdepth(16) opcode(copy)]
    1m 15.75s: info: stream output Audio(128)[codec(ac3) channels(2) sample(48000) bitrate(448000) bitdepth(16) opcode(copy)]
    1m 15.75s: info: SubMode(Remux) -- Display Only forced Subtitle(false)
    1m 15.76s: UILog:MsgWork:WorkStatus_Start
    7m 16.70s: error: filter name(dvd_demux), type(1), id(29), get std_exception(bad allocation)
    7m 46.80s: error: Work 1 failed, Error = control graph control_filter_error error: filter name(dvd_demux), type(1), id(29), get std_exception(bad allocation)
    7m 46.80s: ------------------ convert work failed ------------------
    7m 47.81s: UILog:MsgWork:current work finish : 2
    7m 47.81s: UILog:Run Work to end.
