dvd TROUBLE
dvd9
Label Videodis FEV
DVDFab 9.1.7.2 (2014/11/02 19:02:29)
0m 00.03s: Init Public log : enabled.
0m 00.03s: Init Private log : finish.
0m 00.03s: App info: 2014-10-31
0m 00.03s: App info: 9.1.7.2 9172 Beta
0m 00.03s: Init CrashReportSettings : disabled.
0m 00.03s: Init DVDInfo_Log : enabled.
0m 00.04s: Init Qt_Log : disabled.
0m 00.34s: Profile Manager :: Begin Load Profile
0m 00.34s: Qt Translator file load success
0m 00.35s: App info: client type 2.
0m 00.37s: MobilePlay load: preload successful.
0m 00.49s: MobilePlay load: Load successful.
0m 00.50s: Init process: Transfer settings successful.
0m 00.50s: info: check logpath= C:/Users/Fréddy/Documents/DVDFab9/Log/
0m 00.54s: info: _check_gpu is running ...
0m 01.12s: info: check_gpu run successful
0m 01.13s: info: recommand= 8248, Shrink support= 1, enable= 1, cuda_cap= 1 , cpu_count= 8
0m 01.13s: GPU check: GPUAccelerate-12351
0m 01.13s: GPU check: GPUAccelerate setting-8248, 8248
0m 01.13s: GPU check: CUDA cap-1
0m 01.13s: GPU check: Support coreavc decode-0
0m 01.13s: GPU check: Lighting shrink status-1, 1
0m 01.13s: GPU check: Graphics info 1: NVIDIA GeForce GTX 770 : 9.18.13.4448 : 3.0
0m 01.14s: Init process: Load config successful.
0m 01.14s: Init process: Windows os type is 64bit System Windows 8.
0m 01.14s: Init process: command line in is
0m 01.26s: Reg check: Parse string: ( 55:8260762964 )( 2:8295154495 )( 11:8260762964 )( 20:8260762964 )( 50:8260762964 )( 21:8260762964 )( 22:8260762964 )( 60:8260762964 )( 70:8260762964 )( 61:8260762964 )( 62:8260762964 )( 1:9 )( OV:9171 )( BV:9172 )( S:d199faf63733c55d07cefee3e5d787c5 )
0m 01.27s: Reg check: Option check status-Local
0m 01.27s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:1 )-( Blu-ray to DVD:1:1 )-( DVD to Blu-ray:1:1 )-( File to DVD:1:1 )-( File to Blu-ray:1:1 )-( File Mover:1:0 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:1 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
0m 01.27s: App info: language type FRA.
0m 01.27s: Reg check: Start get sys number.
0m 01.27s: Export Blu-ray source information report : enabled
0m 01.27s: Reg check: Serial number is: 00-ff-3e-91-57-03:88-88-88-88-87-88:00-26-83-2b-cb-ce
0m 01.27s: Reg check: Connect type is: 0
0m 01.27s: Init process: Init GPU settings successful.
0m 02.01s: Profile Manager :: End Load Profile
0m 02.21s: Init preview: Begin init preview play engine.
0m 02.21s: Init preview: Begin init preview play engine(Internal).
0m 02.62s: Reg check: Times of connecting error is: 0
0m 02.62s: Reg check: Parse string: ( S:bc276e5f542370753f9737ba70127240
0m 02.63s: Reg check: Option check status-NewWork
0m 02.66s: Init preview: Init internal engine successful.
0m 03.56s: Burn engine: start init.
0m 03.56s: Burn engine: set log folder.
0m 03.56s: DVD: init read settings.
0m 03.56s: DVD: init write settings.
0m 06.19s: BD: init read settings.
0m 06.19s: BD: init write settings.
0m 06.19s: bd set region B
0m 06.19s: Burn engine: config engine type-0 begin.
0m 06.19s: Burn engine: config engine type-0 end.
0m 06.19s: Burn engine: writer count 2.
0m 06.19s: Burn engine: 0- I:\ [HL-DT-ST BD-RE GGW-H20L YL07 (Scsi)].
0m 06.19s: Burn engine: 1- K:\ [TSSTcorp CDDVDW SE-S204N TS02 (Usb)].
0m 06.19s: Burn engine: end init.
0m 07.70s: Init process: Init setting page successful.
0m 07.71s: QtLog Mode = false
0m 07.71s: Show ProductsInfo Dlg 3
0m 26.02s: Reg check: Start get sys number.
0m 26.03s: Reg check: Serial number is: 00-ff-3e-91-57-03:88-88-88-88-87-88:00-26-83-2b-cb-ce
0m 26.03s: Reg check: Connect type is: 0
0m 26.86s: Reg check: Times of connecting error is: 0
0m 26.87s: Reg check: Option check status-NewWork
0m 31.73s: Reg check: Start get sys number.
0m 31.73s: Reg check: Serial number is: 00-ff-3e-91-57-03:88-88-88-88-87-88:00-26-83-2b-cb-ce
0m 31.74s: Reg check: Connect type is: 0
0m 32.55s: Reg check: Times of connecting error is: 0
0m 32.55s: Reg check: Parse string: ( S:9d0bc671c447fa63cdd9c7d098ce2357
0m 32.56s: Reg check: Option check status-NewWork
0m 32.74s: Reg check: Option check status-NewWork
0m 38.42s: Show UI Step 2
0m 39.04s: Show UI Step 3
0m 39.04s: Start show MainUI.
0m 39.05s: UI manager: switch to Converter mode.
0m 41.22s: allow_test : false
0m 41.49s: Init process: init main ui successful.
0m 41.57s: Init process: show main ui successful.
0m 41.57s: DriveX msg: Init driveX I with I/O mode: 0
0m 41.58s: DriveX msg: Init driveX K with I/O mode: 0
0m 41.63s: opening drive I
0m 41.63s: opened i/o
0m 41.63s: got media type 4
0m 41.87s: got max lba 3361535
0m 41.89s: got disc type 10
0m 41.95s: type DVD-VIDEO
0m 41.95s: volume label TROUBLE
0m 41.95s: DriveX msg: add media in driveX I.
0m 41.95s: DriveX msg: send open media msg to thread for driveX I.
0m 41.98s: Source manager
pen source flag:1,1,1,1
0m 41.98s: opening drive K
0m 42.01s: opened i/o
0m 42.02s: Source manager
0m 42.02s: Source manager: add source id 0.
0m 42.04s: Source open status
VD Yes, 2231-10-11
0m 42.04s: Source open status:BD Yes, 2231-10-11
0m 42.04s: internal path I:/VIDEO_TS/
0m 42.04s: got copyright 0 fd
0m 42.68s: got udf/iso
0m 44.67s: got discinfo
0m 44.67s: pathplayer enabled
0m 46.71s: button: vts_1 menu_1 pgc_1 cell_2 start_1714 end_23550 sector_2097 count_4
0m 53.19s: button: vts_1 menu_1 pgc_2 cell_1 start_23551 end_34459 sector_34157 count_7
0m 53.72s: button: vts_1 menu_1 pgc_3 cell_1 start_34460 end_45372 sector_45069 count_7
0m 54.18s: button: vts_1 menu_1 pgc_4 cell_1 start_45373 end_56286 sector_55983 count_7
0m 54.74s: button: vts_1 menu_1 pgc_6 cell_1 start_67194 end_78102 sector_77800 count_7
0m 55.29s: button: vts_1 menu_1 pgc_5 cell_1 start_56287 end_67193 sector_66936 count_3
0m 55.76s: button: vts_3 menu_1 pgc_1 cell_1 start_0 end_10898 sector_10644 count_4
0m 55.91s: button: vts_3 menu_1 pgc_2 cell_1 start_10899 end_21797 sector_21543 count_6
0m 56.04s: button: vts_3 menu_0 pgc_1 cell_1 start_0 end_10899 sector_10643 count_2
0m 56.17s: button: vts_3 menu_0 pgc_1 cell_2 start_10900 end_21799 sector_21543 count_3
0m 56.48s: button: vts_3 menu_0 pgc_1 cell_3 start_21800 end_32701 sector_32444 count_3
0m 56.63s: button: vts_3 menu_0 pgc_1 cell_4 start_32702 end_43599 sector_43344 count_3
0m 56.82s: button: vts_3 menu_0 pgc_1 cell_5 start_43600 end_54499 sector_54243 count_2
0m 57.25s: button: vts_4 menu_1 pgc_1 cell_1 start_0 end_10917 sector_10608 count_4
0m 58.89s: button: vts_5 menu_1 pgc_1 cell_1 start_0 end_10910 sector_10610 count_4
0m 59.07s: button: vts_5 menu_1 pgc_2 cell_1 start_10911 end_21812 sector_21556 count_6
1m 04.99s: got dvdinfo
1m 05.20s: opened dvd
1m 08.92s: Source manager: open successful.
1m 10.16s: Work manager: create Converter work 0 with source 0 and uiinfo 0( title 0 ).
dvd9
Label Videodis FEV
pen source flag:1,1,1,10m 41.98s: opening drive K
pen source flag:1,1,1,10m 42.02s: Source manager
pen source flag:1,1,1,10m 42.02s: Source manager: add source id 0.
VD Yes, 2231-10-110m 42.04s: Source open status:BD Yes, 2231-10-11
