Blade runner Synch issues..help and guidance needed
    Just backed up the UK version of Blade runner final cut using version 8.2.1.5.
    I backed up to hard drive and then mounted the mini iso using dvdfab virtual drive and set to full disc and put it on a 25gb disc.
    It burnt successfuly but on playback the audio synch is out.
    Can someone please tell me if I can sort this out by changing a setting to keep it in synch?
    Heres the log details.
    DVDFab 8.2.1.5 (2012/10/11 17:35:36)
    0m 01.31s: GPUAccelerate: 3
    0m 01.31s: CUDA cap: 0
    0m 01.31s: Support coreavc decode: 0
    0m 01.31s: Graphics info: ATI Radeon HD 4300/4500 Series : :
    0m 01.34s: Qt Translator file load success
    0m 01.35s: Load config successful.
    0m 01.39s: Init profile data driver sucessful.
    0m 04.43s: Init GPU settings sucessful.
    0m 04.43s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
    0m 04.45s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
    0m 04.64s: Config ExBar successful.
    0m 04.64s: dvd2dvd have 8 elements.
    0m 04.75s: dvd2mobile have 31 elements.
    0m 05.40s: blu-ray2blu-ray have 4 elements.
    0m 05.43s: blu-ray2mobile have 20 elements.
    0m 05.85s: blu-ray23d have 7 elements.
    0m 05.98s: blu-ray2dvd have 1 elements.
    0m 06.00s: file2mobile have 30 elements.
    0m 06.65s: file2dvd have 1 elements.
    0m 06.67s: file2bluray have 1 elements.
    0m 06.96s: Config work ui controls successful.
    0m 10.06s: Init burn engine successful.
    0m 10.14s: StartNotify successful.
    0m 10.18s: opening drive D
    0m 10.20s: opened i/o
    0m 10.20s: got media type 16
    0m 10.21s: got disc type 0
    0m 10.21s: got max lba 0
    0m 10.21s: opening drive F
    0m 10.21s: opened i/o
    0m 10.23s: got media type 16
    0m 10.23s: got disc type 0
    0m 10.23s: got max lba 14122527
    0m 10.25s: type Blu-ray BDMV
    0m 10.25s: volume label BLADERUNNER_FINAL_EU
    0m 10.43s: failed to open 0
    0m 12.82s: aacs 0 bd+ 0
    0m 12.84s: got discinfo
    0m 12.85s: got bdmv
    0m 13.07s: got extended bdinfo
    0m 13.07s: opened blu-ray
    1m 05.56s: Blu-ray Copy: Full Disc
    1m 05.57s: Source: F:/BDMV/
    1m 05.57s: SourceSize: 27581 MB
    1m 05.57s: RemoveHDAudio: 0
    1m 05.57s: OutputSize: 23000 MB
    1m 05.57s: OutputDisc: BDMV
    1m 05.57s: OutputTarget: BD25
    1m 05.57s: OutputVideo: 1080p/i
    1m 06.00s: info: enable bd copy(mode=0)
    1m 06.00s: info: video encode mode(0), bitrate(10182), lr-encode(no)
    1m 06.00s: info: streams(4113.2)
    1m 06.00s: info: blu-ray copy begin (unit[elem[atomic[00001.m2ts]]])
    1m 06.00s: try to use gpu acceleration(2) for video decoding
    1m 06.00s: DXVA GPU acceleration for video decoding enabled
    1m 09.59s: info: h264_encode: encode param profile(2) level(41) bitrate(10181)
    1m 13.59s: info: processing source(00001.m2ts)
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(8 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(7 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(6 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(5 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(4 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(3 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(2 - 0), drop it
    1m 29.53s: info: filter(505.04), reach the mux end, something not out(1 - 0), drop it
    1m 36.57s: info: group(elem[atomic[00001.m2ts]]) playtime(11011 ms) source(22 MB) request(15 MB) real(4 MB) bitrate(10181 kbps)
    1m 36.57s: compress finished: groups request(15 MB, 15 MB) real(4 MB) average_bitrate(10182 kbps)
    1m 37.14s: info: enable bd copy(mode=0)
    1m 37.14s: info: video encode mode(0), bitrate(4087), lr-encode(no)
    1m 37.14s: info: streams(4113.2)
    1m 37.14s: info: blu-ray copy begin (unit[elem[atomic[00004.m2ts]]])
    1m 38.23s: info: h264_encode: encode param profile(2) level(41) bitrate(4087)
    1m 42.23s: info: processing source(00004.m2ts)
    2m 10.92s: info: group(elem[atomic[00004.m2ts]]) playtime(37037 ms) source(29 MB) request(21 MB) real(21 MB) bitrate(4087 kbps)
    2m 10.93s: compress finished: groups request(21 MB, 21 MB) real(21 MB) average_bitrate(4087 kbps)
    2m 11.68s: info: enable bd copy(mode=0)
    2m 11.68s: info: video encode mode(0), bitrate(3818), lr-encode(no)
    2m 11.68s: info: streams(4113.2)
    2m 11.68s: info: blu-ray copy begin (unit[elem[atomic[00003.m2ts]]])
    2m 11.68s: try to use gpu acceleration(2) for video decoding
    2m 11.68s: using dmo decoder
    2m 12.93s: info: h264_encode: encode param profile(2) level(41) bitrate(3818)
    2m 16.93s: info: processing source(00003.m2ts)
    4m 22.12s: info: group(elem[atomic[00003.m2ts]]) playtime(330296 ms) source(228 MB) request(160 MB) real(161 MB) bitrate(3818 kbps)
    4m 22.12s: compress finished: groups request(160 MB, 160 MB) real(161 MB) average_bitrate(3818 kbps)
    4m 24.04s: info: enable bd copy(mode=0)
    4m 24.04s: info: video encode mode(0), bitrate(3749), lr-encode(no)
    4m 24.04s: info: streams(4113.2)
    4m 24.04s: info: blu-ray copy begin (unit[elem[atomic[00085.m2ts]]])
    4m 24.04s: try to use gpu acceleration(2) for video decoding
    4m 24.04s: using dmo decoder
    4m 25.06s: info: h264_encode: encode param profile(2) level(41) bitrate(3749)
    4m 29.06s: info: processing source(00085.m2ts)
    6m 32.62s: info: group(elem[atomic[00085.m2ts]]) playtime(330296 ms) source(1102 MB) request(1034 MB) real(1031 MB) bitrate(3749 kbps)
    6m 32.64s: compress finished: groups request(1034 MB, 1034 MB) real(1031 MB) average_bitrate(3749 kbps)
    6m 35.50s: info: enable bd copy(mode=0)
    6m 35.54s: info: video encode mode(0), bitrate(3763), lr-encode(no)
    6m 35.54s: info: streams(4113.2)
    6m 35.54s: info: blu-ray copy begin (unit[elem[atomic[00086.m2ts]]])
    6m 35.54s: try to use gpu acceleration(2) for video decoding
    6m 35.54s: using dmo decoder
    6m 37.60s: info: h264_encode: encode param profile(2) level(41) bitrate(3763)
    6m 41.60s: info: processing source(00086.m2ts)
    8m 46.71s: info: group(elem[atomic[00086.m2ts]]) playtime(330296 ms) source(1111 MB) request(1044 MB) real(1041 MB) bitrate(3763 kbps)
    8m 46.73s: compress finished: groups request(1044 MB, 1044 MB) real(1041 MB) average_bitrate(3763 kbps)
    8m 47.95s: info: enable bd copy(mode=0)
    8m 47.98s: info: video encode mode(0), bitrate(3763), lr-encode(no)
    8m 47.98s: info: streams(4113.2)
    8m 47.98s: info: blu-ray copy begin (unit[elem[atomic[00087.m2ts]]])
    8m 47.98s: try to use gpu acceleration(2) for video decoding
    8m 47.98s: using dmo decoder
    8m 49.04s: info: h264_encode: encode param profile(2) level(41) bitrate(3763)
    8m 53.04s: info: processing source(00087.m2ts)
    10m 57.42s: info: group(elem[atomic[00087.m2ts]]) playtime(330296 ms) source(1111 MB) request(1044 MB) real(1041 MB) bitrate(3763 kbps)
    10m 57.43s: compress finished: groups request(1044 MB, 1044 MB) real(1041 MB) average_bitrate(3763 kbps)
    10m 59.96s: info: enable bd copy(mode=0)
    10m 59.96s: info: video encode mode(0), bitrate(11806), lr-encode(no)
    10m 59.96s: info: streams(4113.2)
    10m 59.96s: info: blu-ray copy begin (unit[elem[atomic[00047.m2ts]]])
    10m 59.96s: try to use gpu acceleration(2) for video decoding
    10m 59.96s: DXVA GPU acceleration for video decoding enabled
    11m 01.01s: info: h264_encode: encode param profile(2) level(41) bitrate(11806)
    11m 05.01s: info: processing source(00047.m2ts)
    70m 44.00s: info: filter(505.04), reach the mux end, something not out(48 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(47 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(46 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(45 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(44 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(43 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(42 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(41 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(40 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(39 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(38 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(37 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(36 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(35 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(34 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(33 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(32 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(31 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(30 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(29 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(28 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(27 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(26 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(25 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(24 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(23 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(22 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(21 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(20 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(19 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(18 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(17 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(16 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(15 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(14 - 0), drop it
    70m 44.01s: info: filter(505.04), reach the mux end, something not out(13 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(12 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(11 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(10 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(9 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(8 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(7 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(6 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(5 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(4 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(3 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(2 - 0), drop it
    70m 44.03s: info: filter(505.04), reach the mux end, something not out(1 - 0), drop it
    70m 51.06s: info: group(elem[atomic[00047.m2ts]]) playtime(7056841 ms) source(23900 MB) request(19394 MB) real(19285 MB) bitrate(11806 kbps)
    70m 51.07s: compress finished: groups request(19394 MB, 19394 MB) real(19285 MB) average_bitrate(11806 kbps)
    85m 31.07s: opening drive D
    85m 31.64s: opened i/o
    85m 31.64s: got media type 16
    85m 31.65s: got disc type 0
    85m 31.65s: got max lba 11603615
    85m 32.43s: type Blu-ray BDMV
    85m 32.43s: volume label BLADERUNNER_FINAL_EU
    Hi Gary1609
    Give this a try.
    Open Fab click the Click the Green at top right corner of the DVD Fab screen, and open Common Settings > General >A/V Codec, put a check in Disable all GPU codes and make sure they are set to Software, restart Fab and try again.
    Hope this helps
    CBR929
      Hi Gary1609
      Give this a try.
      Hope this helps
      CBR929
      Thank you for your quick reply CBR929 that has worked a treat
        Glad to help.
        CBR929
