Burning problem: tried everything already please help
    My blank DVD-R disk was immediately rejected whenever I tried to burn an .iso file using DVDFab. Below is the log and the error message.
    From file dvdfab_internal:
    DVDFab 8.1.7.8 (2012/05/03 14:12:46)
    0m 01.09s: GPUAccelerate: 12347
    0m 01.09s: CUDA cap: 0
    0m 01.09s: Support coreavc decode: 0
    0m 01.09s: Graphics info: NVIDIA GeForce 210 : 2.30 : 1.2
    0m 01.10s: Qt Translator file load success
    0m 01.95s: Load config successful.
    0m 01.96s: Init profile data driver sucessful.
    0m 06.84s: Init GPU settings sucessful.
    0m 06.84s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
    0m 06.84s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
    0m 07.23s: Config ExBar successful.
    0m 07.23s: dvd2dvd have 8 elements.
    0m 07.39s: dvd2mobile have 29 elements.
    0m 08.12s: blu-ray2blu-ray have 4 elements.
    0m 08.15s: blu-ray2mobile have 18 elements.
    0m 08.60s: blu-ray23d have 7 elements.
    0m 08.74s: blu-ray2dvd have 1 elements.
    0m 08.78s: file2mobile have 28 elements.
    0m 09.49s: file2dvd have 1 elements.
    0m 09.53s: file2bluray have 1 elements.
    0m 10.15s: Config work ui controls successful.
    0m 14.90s: Init burn engine successful.
    0m 14.98s: StartNotify successful.
    0m 16.49s: drive D
    0m 16.49s: type DVD-VIDEO
    0m 16.49s: volume label MISSION_IMPOSSIBLE_4
    0m 16.56s: got copyright 1 f6
    0m 17.07s: got udf/iso
    0m 21.06s: got discinfo
    0m 21.09s: pathplayer enabled
    0m 43.93s: got dvdinfo
    0m 43.93s: opened dvd
    0m 23.37s: failed to get max sector
    0m 25.82s: iso E:/DPTempE/Write This ISO/MISSION_IMPOSSIBLE_4.iso
    0m 25.82s: type DVD-VIDEO
    0m 25.82s: volume label MISSION_IMPOSSIBLE_4
    0m 25.87s: got copyright 0 0
    0m 26.29s: got udf/iso
    0m 26.65s: got discinfo
    0m 26.67s: pathplayer enabled
    0m 40.54s: got dvdinfo
    0m 40.54s: opened dvd
    0m 47.01s: failed to get max sector
    And from file dvdfab_process:
    Burn DVD image (E:\DPTempE\Write This ISO\MISSION_IMPOSSIBLE_4.iso) started: 16:13:48
    Task_2 failed! Error=111: 16:13:57
    I'm desperate please help . Thank you in advance.
    roatan,
    let me first clarify couple of things:
    (1) DVDFab doesn't burn anything...
    (2) DVDFab doesn't have built-in burning engine, but uses third-party: VSO, ImgBurn, or Nero...
    So first question is which burning engine you are using?
    I have a suspicion that you are using VSO. If that's the case, please don't even look for solution, just install and set up ImgBurn to work with DVDFab
    sigpic
      Originally posted by IPopov50 View Post
      roatan,
      Hi my friend
      DVD Fab does now, see pic
      @ roatan
      If you would like to use ImgBurn as your burn engine you will find instructions in the link in my signature.
      Please post your most recent burn log.
      Thanks
      CBR929
        @ IPopov50
        I wasn't aware that DVDFab has not built-in burning engine. I've been using previous versions for the last 2 years and never had problem burning. All I've been doing is just click to the .iso file as source and for destination just choose my DVD writer. Something happened behind the scene and the disk got written. That is all up until the latest version of DVDFab. What's VSO? I don't recall installing such a program though my computer does have Nero.
        @ CBR929
        It just seems strange that apparently I've had enough to burn the DVDs but suddenly it doesn't work anymore. Maybe something needs to be reset and/or reconnect? If I can't re-establish what I have before I will follow your advice and download ImgBurn.
        Thank you both for your responses.
          Agree with both my friends, dump VSO and install Img.
          VSO has a history of being problematic for many users...although to be fair, it performs just fine for many.
          Img is more reliable, more configurable and has much better support.
          Be certain to set up AWS (Automatic Write Speed) in Img as well. It is well worth a couple of minutes.
          The confusion with VSO is a result of it being "bundled" with Fab and it is installed by virtue of the default settings;
          you would have to manually opt out of the VSO install during normal installation of Fab.
          I agree with you, it is strange, but not uncommon behavior with respect to VSO.
          It may be a relatively easy fix, but perhaps not and believe me, it can get much worse in attempting a fix.
          To quote Will Rogers,
          "When you find yourself in a hole, quit digging"
