Using DVD Copy + Boxee (small issue)
    Hi Guys,
    I have been using DVD Copy with the new Boxee Box and everything has been working great. However, with a couple of the most recent copies, Boxee plays them back 2x speed. I can press rewind for a second and it fixes itself, but I'm trying to figure out what the problem is so that I don't have to do that. The .vob and .ifo files play fine in VLC on my computer which makes me think it's Boxee, but it's been playing everything else fine.
    Any thoughts? Thanks.
    Hi BuffaloBru,
    Since the ripped vob files can play well in VLC, that means DVDFab copied this movie correctly and successfully, we suggest you contact the Boxee service team to get more advice and check if you need update or fix something for it.
    Regards,
    mona
