Ok,
The first few movies I ripped to my HD and converted to MKV went just fine, albeit slow. This new Blu Ray of Wall Street Money never sleeps hangs after about 10 hours of compression indicating like .7 FPS and 00:00 time left.
Process:
First I rip the main movie using Blu ray copy to an ISO on my HD (no compression)
Then I chose blu ray ripper to MKV. I select the ISO and use mkv.H264audio copy and for the size of the file, around 8-9GB with constant bit rate, full 1080p, everything else set to default.
Pentium 4 3.00Ghz
2GB RAM
New Nvidia video card on the way to replace an older ATI card.
Settings:
all encoding and decoding to "Software" and default otherwise. I have tried resetting the DMA.
Anyone know what I am doing wrong?
Thanks,
Brandon
Logs:
DVDFab 8.0.7.3 (2011/02/09 21:04:21)
0m 01.18s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 35.79s: detected blu-ray
0m 35.79s: iso C:\Wall Street Money Never Sleeps\Wall Street\WALL_STREET_2.iso
0m 35.79s: blu-ray type 1
0m 35.79s: volume label WALL_STREET_2
0m 37.71s: root 3E48B99C________WALL_STREET_2:WALL_STREET_2:WALL_S TREET_2:WALL_STREET_2
0m 37.75s: aacs 0 bd+ 0
0m 37.78s: got discinfo
0m 37.79s: got bdmv
0m 37.85s: got extended bdinfo
0m 37.85s: opened blu-ray
77m 30.90s:
77m 30.93s: create config(5)
77m 30.93s: convert profile(mkv.h264.audiocopy)
77m 30.93s: blu-ray playlist(0) angle(0) chapter(1->29)
77m 30.93s: stream(4113,AVC,1) stream(4352,DTS-HD MA,0) stream(4608,PGS,8)
77m 30.95s: info: set output video frame_rate(24000/1001)
77m 31.03s: subpicture preset(2), mode(2)
77m 31.06s: processing source(00800.m2ts)
77m 31.07s: using software decoder(h264 multi-thread)
77m 32.32s: h264_encode: encode param profile(2) level(51) bitrate(8687)
77m 34.34s: subpicture(4608) mode(2)
605m 25.71s: ------ cancel all mobile work -------
Burn log
2011-02-09 19:23:51 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
2011-02-09 19:23:51 Info OS : Microsoft Windows XP MCE 2005 (Build 2600: Service Pack 3)
2011-02-09 19:23:51 ---- ******************** Log session start 09-Feb 19:23:51.161 PID 2848********************
2011-02-09 19:23:43 ---- ******************** Log session stop 09-Feb 19:23:43.363 PID 3628********************
2011-02-09 18:58:30 Info Current Drive selected : 0:1:0 - PIONEER BD-RW BDR-206 1.04 [D] (Ide)
2011-02-09 18:58:30 Info Using Advanced SPTI interface
2011-02-09 18:58:30 Info System default language : English (United States)
2011-02-09 18:58:30 Info User default language : English (United States)
2011-02-09 18:58:30 Info DLL Version : 4.0.15.480
2011-02-09 18:58:30 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
2011-02-09 18:58:30 Info Version : 8, 0, 7, 3
2011-02-09 18:58:30 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
2011-02-09 18:58:30 Info OS : Microsoft Windows XP MCE 2005 (Build 2600: Service Pack 3)
2011-02-09 18:58:30 ---- ******************** Log session start 09-Feb 18:58:30.722 PID 3628********************
2011-02-09 18:26:31 ---- ******************** Log session stop 09-Feb 18:26:31.234 PID 3964********************
2011-02-09 07:49:49 Info Current Drive selected : 0:1:0 - PIONEER BD-RW BDR-206 1.04 [D] (Ide)
2011-02-09 07:49:49 Info Using Advanced SPTI interface
2011-02-09 07:49:49 Info System default language : English (United States)
2011-02-09 07:49:49 Info User default language : English (United States)
2011-02-09 07:49:49 Info DLL Version : 4.0.15.480
2011-02-09 07:49:49 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
2011-02-09 07:49:49 Info Version : 8, 0, 7, 3
Process:
Pentium 4 3.00Ghz
2GB RAM
Settings:
Thanks,
Brandon
Logs:
0m 37.79s: got bdmv
77m 30.90s:
Burn log
