I've tryed software only (disabled gpu) and used my normal setting for bluray conversion. trying to rip the discs to iphone .m4v
The audio just dont want to line up. no other movie seems to be giving me this problem.
DVDFab 8.2.2.2 (2012/12/01 23:15:50)
0m 00.85s: GPUAccelerate: 12351
0m 00.85s: CUDA cap: 1
0m 00.85s: Support coreavc decode: 0
0m 00.85s: Graphics info: NVIDIA GeForce GTX 660 Ti : 5.0 : 3.0
0m 00.85s: Qt Translator file load success
0m 00.88s: Load config successful.
0m 00.93s: Init profile data driver sucessful.
0m 02.47s: Init GPU settings sucessful.
0m 02.47s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 02.48s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 02.65s: Config ExBar successful.
0m 02.65s: dvd2dvd have 8 elements.
0m 02.75s: dvd2mobile have 29 elements.
0m 03.31s: blu-ray2blu-ray have 4 elements.
0m 03.33s: blu-ray2mobile have 18 elements.
0m 03.68s: blu-ray23d have 7 elements.
0m 03.80s: blu-ray2dvd have 1 elements.
0m 03.82s: file2mobile have 28 elements.
0m 04.36s: file2dvd have 0 elements.
0m 04.36s: file2bluray have 0 elements.
0m 04.64s: Config work ui controls successful.
0m 05.99s: Init burn engine successful.
0m 06.05s: StartNotify successful.
0m 06.10s: opening drive F
0m 06.10s: opened i/o
0m 06.10s: got media type 16
0m 06.13s: got disc type 0
0m 06.13s: got max lba 23720703
0m 06.19s: type Blu-ray BDMV
0m 06.19s: volume label QUEENS BLADE DISC 1
0m 06.56s: aacs 0 bd+ 0
0m 06.58s: got discinfo
0m 06.59s: got bdmv
0m 07.06s: got extended bdinfo
0m 07.06s: opened blu-ray
0m 07.45s: WorkAttr::Init Start
0m 07.48s: WorkAttr::Init OK: iPhone4.mp4
0m 25.72s:
0m 25.72s: info: create config(5)
0m 25.72s: info: convert profile(iPhone4.mp4)
0m 25.73s: info: bluray playlist(2),angle(0),chapter(1->31),3D(0)
0m 25.73s: info: streams((4113.2)(4352.2))
0m 47.44s:
0m 47.44s: info: create config(5)
0m 47.45s: info: convert profile(iPhone4.mp4)
0m 47.45s: info: bluray playlist(2),angle(0),chapter(1->31),3D(0)
0m 47.45s: info: streams((4113.2)(4352.2))
0m 47.46s: info: not set correct fourcc for video(28)
0m 47.46s: info: set output video frame_rate(24000/1001)
0m 47.46s: info: enable multi-thread software decoder
0m 48.49s: info: h264_encode: encode param profile(1) level(31) bitrate(1865)
0m 52.52s: info: processing source(00002.m2ts)
7m 09.02s: info: processing source(00003.m2ts)
13m 18.61s: info: processing source(00004.m2ts)
19m 38.58s: info: processing source(00005.m2ts)
25m 46.63s: info: processing source(00006.m2ts)
31m 50.62s: info: processing source(00007.m2ts)
38m 41.89s:
------ finish mobile work ------
DVDFab 8.2.2.2 (2012/12/02 23:50:39)
0m 01.06s: GPUAccelerate: 12351
0m 01.06s: CUDA cap: 1
0m 01.06s: Support coreavc decode: 0
0m 01.06s: Graphics info: NVIDIA GeForce GTX 660 Ti : 5.0 : 3.0
0m 01.07s: Qt Translator file load success
0m 01.07s: import key file F:\ 1
0m 01.10s: Load config successful.
0m 01.16s: Init profile data driver sucessful.
0m 02.95s: Init GPU settings sucessful.
0m 02.95s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 02.96s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 03.14s: Config ExBar successful.
0m 03.14s: dvd2dvd have 8 elements.
0m 03.24s: dvd2mobile have 29 elements.
0m 03.81s: blu-ray2blu-ray have 4 elements.
0m 03.83s: blu-ray2mobile have 18 elements.
0m 04.19s: blu-ray23d have 7 elements.
0m 04.31s: blu-ray2dvd have 1 elements.
0m 04.33s: file2mobile have 28 elements.
0m 04.88s: file2dvd have 0 elements.
0m 04.88s: file2bluray have 0 elements.
0m 05.14s: Config work ui controls successful.
0m 12.80s: Init burn engine successful.
0m 12.84s: StartNotify successful.
0m 12.90s: opening drive F
0m 12.90s: opened i/o
0m 12.90s: got media type 16
0m 12.91s: got disc type 0
0m 12.91s: got max lba 23663391
0m 12.93s: type Blu-ray BDMV
0m 12.93s: volume label QUEENS BLADE SEASON 2 DISC 1
0m 13.36s: aacs 0 bd+ 0
0m 13.38s: got discinfo
0m 13.43s: got bdmv
0m 14.01s: got extended bdinfo
0m 14.01s: opened blu-ray
0m 14.31s: WorkAttr::Init Start
0m 14.34s: WorkAttr::Init OK: iPhone4.mp4
0m 25.73s: WorkAttr::Init Start
0m 25.76s: WorkAttr::Init OK: iPhone4.mp4
3m 18.26s: WorkAttr::Init Start
3m 18.29s: WorkAttr::Init OK: iPhone4.mp4
4m 17.89s:
------ begin mobile work(1/2) ------
4m 17.89s: info: create config(5)
4m 17.89s: info: convert profile(iPhone4.mp4)
4m 17.89s: info: bluray playlist(2),angle(0),chapter(1->31),3D(0)
4m 17.89s: info: streams((4113.2)(4352.2))
4m 17.90s: info: not set correct fourcc for video(28)
4m 17.90s: info: set output video frame_rate(24000/1001)
4m 17.90s: try to use gpu acceleration(1) for video decoding
4m 17.90s: CUDA GPU acceleration for video decoding enabled
4m 17.90s: CUDA GPU acceleration for video encoding enabled
4m 17.91s: info: h264_encode: encode param profile(1) level(31) bitrate(1865)
4m 18.01s: info: processing source(00002.m2ts)
8m 41.82s: info: processing source(00003.m2ts)
13m 06.08s: info: processing source(00004.m2ts)
17m 31.29s: info: processing source(00005.m2ts)
21m 58.93s: info: processing source(00006.m2ts)
26m 26.21s: info: processing source(00007.m2ts)
31m 12.85s:
those are the 2 examples i tryed last night, with no luck.
0m 06.59s: got bdmv
0m 25.72s:
0m 47.44s:
38m 41.89s:
0m 13.43s: got bdmv
4m 17.89s:
31m 12.85s:
