Bluray Conversion Audio Sync problems
    BD Ripper (3D Plus) Bluray Conversion Audio Sync problems
    I've noticed others have had the same problem. Upgraded to newest release and every movie that is converted from bluray to mp4 format has audio sync issues. It appears the frame rate is off because the sync issue gets worse towards the middle and end of the movie. (Settings are for frame rate to be same as source.)
    Reviewing other similar difficulties mentioned in the forums, this doesn't appear to be an isolated problem. Any solutions?
    You need to post your internal log when you have a problem or else it's guess work. My guess is your output audio is AAC I have the same issues when I convert an HD audio stream to AAC audio. I use AC3 for the audio output stream and haven't had an issue. I just made an mp4 of Smaug using AC3 audio output, to check this, and the A/V sync is spot on throughout.
      Looks like you're right.
      Audio setting was on AAC. Will try again on AC3, if its still a problem, then will post log.
        Post either way, interested if it works for you.
          Problem fixed
          Seems to have fixed the problem. Thanks
            Great! Thanks for the feedback.
              Same problem
              ...but my output is MKV, audiocopy, not AAC.
              And it seems most of the movies I did rip from blu-ray has this issue... From a very long time.
              my log :
              DVDFab 9.1.4.6 (2014/05/22 23:17:09)
              0m 00.96s: Init Public log : enabled.
              0m 00.96s: Init Private log : finish.
              0m 00.96s: App info: 2014-5-22
              0m 00.96s: App info: 9.1.4.6 9146 Official
              0m 01.26s: Init CrashReportSettings : enabled.
              0m 01.26s: Init DVDInfo_Log : enabled.
              0m 01.26s: Init Qt_Log : disabled.
              0m 04.10s: Profile Manager :: Begin Load Profile
              0m 04.36s: Qt Translator file load success
              0m 04.43s: App info: client type 2.
              0m 04.44s: Fabplay load: preload successful.
              0m 04.49s: Fabplay load: Load successful.
              0m 04.49s: Init process: Transfer settings successful.
              0m 04.49s: info: fabcheck logpath= C:/Users/Chris/Documents/DVDFab9/Log/
              0m 05.25s: info: fab_check_gpu is running ...
              0m 15.26s: info: fab_check_gpu run out of time , terminating
              0m 15.26s: info: recommand= 0, Shrink support= 0, enable= 0, cuda_cap= 0 , cpu_count= 4
              0m 15.26s: GPU check: GPUAccelerate-0
              0m 15.26s: GPU check: GPUAccelerate setting-0, 0
              0m 15.26s: GPU check: CUDA cap-0
              0m 15.26s: GPU check: Support coreavc decode-0
              0m 15.26s: GPU check: Lighting shrink status-0, 0
              0m 15.26s: Init process: Load config failed.
              0m 15.26s: Init process: Windows os type is 64bit System Windows 7.
              0m 15.26s: Init process: command line in is
              0m 15.61s: Reg check: Parse string: ( 2:8260762964 )( 11:8260762964 )( 20:8260762964 )( 21:8260762964 )( 22:8260762964 )( 60:8260762964 )( 1:0 )( 50:0 )( 62:0 )( 70:0 )( OV:9146 )( BV:9143 )( S:9dfe4af537e6f8c61f11ac2afab8b9c8 )
              0m 15.62s: Reg check: Option check status-Local
              0m 15.62s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:0:0 )-( Blu-ray to DVD:1:1 )-( File to DVD:1:0 )-( File to Blu-ray:0:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:0:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
              0m 15.62s: App info: language type FRA.
              0m 15.62s: Reg check: Start get sys number.
              0m 15.62s: Reg check: Serial number is: 00-ff-f9-0a-32-f1:bc-ae-c5-92-a8-7b
              0m 15.62s: Reg check: Connect type is: 0
              0m 15.62s: Init process: Init GPU settings successful.
              0m 16.17s: Init preview: Begin init preview play engine.
              0m 16.17s: Init preview: Begin init preview play engine(XBMC).
              0m 16.95s: Reg check: Times of connecting error is: 0
              0m 16.95s: Reg check: Parse string: ( S:5259bf1f6b2b4f6d387d71594948f586
              0m 17.39s: Reg check: Option check status-NewWork
              0m 20.83s: Profile Manager :: End Load Profile
              0m 23.46s: Init preview: Init internal engine successful.
              0m 33.20s: Burn engine: start init.
              0m 40.83s: Burn engine: engine type-0.
              0m 40.83s: Burn engine: writer count 1.
              0m 40.83s: Burn engine: 0- M:\ [HL-DT-ST BDDVDRW CH10LS20 1.00 (Ide)].
              0m 40.83s: Burn engine: end init.
              0m 41.78s: Init process: Init setting page successful.
              0m 41.78s: QtLog Mode = false
              0m 41.78s: Show UI Step 2
              0m 42.13s: Show UI Step 3
              0m 42.13s: Start show MainUI.
              0m 42.13s: UI manager: switch to Converter mode.
              0m 44.63s: allow_test : false
              0m 50.51s: Init process: init main ui successful.
              0m 51.45s: Init process: show main ui successful.
              0m 51.45s: DriveX msg: Init driveX M with I/O mode: 0
              0m 51.64s: opening drive M
              0m 51.64s: opened i/o
              0m 51.65s: got media type 15
              0m 54.31s: got max lba 23310047
              0m 55.46s: got disc type 20
              0m 55.46s: type Blu-ray BDMV
              0m 55.46s: volume label Spider-Man 2
              0m 55.47s: DriveX msg: add media in driveX M.
              0m 55.47s: DriveX msg: send open media msg to thread for driveX M.
              0m 59.75s: opening drive M
              0m 59.75s: opened i/o
              0m 59.75s: got media type 15
              1m 00.14s: got max lba 23310047
              1m 01.28s: got disc type 20
              1m 01.28s: type Blu-ray BDMV
              1m 01.28s: volume label Spider-Man 2
              1m 01.28s: Source manager: add source id 0.
              1m 01.29s: Source open statusVD Yes, 2231-10-11
              1m 01.29s: Source open status:BD Yes, 2231-10-11
              1m 01.29s: internal path M:/BDMV/
              1m 01.87s: aacs 1 bd+ 0
              1m 02.19s: got bdmv
              1m 02.58s: movie name: spider-man 2 (2004)
              1m 02.58s: got agid 0
              1m 02.60s: sent host cert chal
              1m 02.60s: got drive cert chal
              1m 02.60s: BEC 0
              1m 02.60s: DRIVE_VENDOR 0x0116
              1m 02.64s: got drive key
              1m 02.64s: got host key signature
              1m 02.64s: verified drive signature
              1m 02.64s: verified host signature
              1m 02.67s: sent host signature and key point
              1m 02.67s: got bus key
              1m 02.67s: got volume id
              1m 02.67s: got volume id mac
              1m 02.67s: volume id is correct
              1m 02.67s: got vid
              1m 02.79s: blu-ray F5B8DE7E0DAB6DAD99EA3C13F3051F53CAD4F8ED
              1m 03.30s: cert BEE=0x00 same
              1m 08.18s: D 1D283E17
              1m 08.18s: main playlist 00002.mpls
              1m 08.18s: selected region B
              1m 08.18s: got vuk
              1m 08.19s: got unit key 4
              1m 28.62s: got bdmv
              1m 49.06s: got extended bdinfo
              1m 49.06s: opened blu-ray
              1m 49.41s: Source manager: open successful.
              1m 49.93s: Work manager: create Converter work 0 with source 0 and uiinfo 0( title 2 ).
              1m 53.58s: ========WorkAttr::SetSource=======
              1m 53.58s: Source Video Size Original : 1920 x 800
              1m 53.58s: Source Video Size Display : 1920 x 800
              1m 53.58s: Source Video FPS : 24000 / 1001
              1m 53.58s: Source Video Bitrate : 1200
              1m 53.59s: Source Audio Bitrate : 0
              1m 53.59s: Source Audio Channels : 6
              1m 53.59s: Source Audio Volume : 100
              1m 53.59s: Work Profile : MKV.Default
              2m 00.18s: Work manager: create Converter work 1 with source 0 and uiinfo 0( title 1 ).
              2m 05.74s: ========WorkAttr::SetSource=======
              2m 05.74s: Source Video Size Original : 1920 x 800
              2m 05.74s: Source Video Size Display : 1920 x 800
              2m 05.74s: Source Video FPS : 24000 / 1001
              2m 05.74s: Source Video Bitrate : 1200
              2m 05.74s: Source Audio Bitrate : 0
              2m 05.74s: Source Audio Channels : 6
              2m 05.74s: Source Audio Volume : 100
              2m 05.74s: Work Profile : MKV.Default
              2m 50.76s: UILog:OnMsgToolbar_Start
              2m 50.77s: UILog:Msg Start : ready start
              2m 50.77s: UILog:Msg Start : start test run work
              2m 50.77s: UILog:right button to null, work falg = -1
              2m 50.78s: UILog:Msg Start : run work
              2m 50.78s: UILog:Run current Work.
              2m 50.78s: UILog:Begin work Converter.
              2m 50.78s: UILog:Begin work copy or converter.
              2m 50.78s: Start check Blu-ray Ripper (3D Plus) register status.
              2m 50.78s: End check Blu-ray Ripper (3D Plus) register status: Enable
              2m 50.78s: UILog:start running at thread.
              2m 50.78s: UILog:return flag at start running at thread ok.
              2m 50.81s: OPList at BD Converter : (4113.2),(4352.1),(4358.1),(4608.16),(4609.16),(46 14.16),(4619.16),(4621.16)
              2m 50.81s: Blu-ray Converter (3D Plus) check watermark flag: 0
              2m 50.81s: ------------------ convert work begin(1/1) ------------------
              2m 50.81s: start fab process
              2m 50.82s: info: create config(bluray2video)
              2m 50.82s: info: use profile(MKV.Default)
              2m 50.82s: info: bluray playlist(1),angle(0),chapter(1->52),BDAV(no)
              2m 50.82s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
              2m 50.85s: info: stream input@ Video(4113)[codec(h264) size(1920*1080) fps(24000/1001) interlace(0) duration(0)sec opcode(compress)]
              2m 50.96s: info: perset file config OK !
              2m 50.96s: info: set output video frame_rate(24000/1001)
              2m 50.96s: info: stream output Video(4113)[codec(h264) size(1920*800) fps(24000/1001) interlace(0) bitrate(9207) duration(0)sec]
              2m 50.97s: info: stream input@ Audio(4352)[codec(dca) channels(6) sample(48000) bitrate(0) bitdepth(16) opcode(copy)]
              2m 50.97s: info: stream output Audio(4352)[codec(dca) channels(6) sample(48000) bitrate(0) bitdepth(16) opcode(copy)]
              2m 50.97s: info: stream input@ Audio(4358)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(0) opcode(copy)]
              2m 50.97s: info: stream output Audio(4358)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(0) opcode(copy)]
              2m 50.97s: info: stream input@ SubPicture(4608)[codec(pgssub) language(English) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(4608)[codec(xsub) language(English)]
              2m 50.97s: info: stream input@ SubPicture(4609)[codec(pgssub) language(English) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(4609)[codec(xsub) language(English)]
              2m 50.97s: info: stream input@ SubPicture(4614)[codec(pgssub) language(French) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(4614)[codec(xsub) language(French)]
              2m 50.97s: info: stream input@ SubPicture(4619)[codec(pgssub) language(English) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(4619)[codec(xsub) language(English)]
              2m 50.97s: info: stream input@ SubPicture(4621)[codec(pgssub) language(French) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(4621)[codec(xsub) language(French)]
              2m 50.97s: info: stream input@ SubPicture(16781824)[codec(pgssub) language(English) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(16781824)[codec(xsub) language(English)]
              2m 50.97s: info: stream input@ SubPicture(16781825)[codec(pgssub) language(English) opcode(extract)]
              2m 50.97s: info: stream output SubPicture(16781825)[codec(xsub) language(English)]
              2m 50.98s: info: stream input@ SubPicture(16781830)[codec(pgssub) language(French) opcode(extract)]
              2m 50.98s: info: stream output SubPicture(16781830)[codec(xsub) language(French)]
              2m 50.98s: info: stream input@ SubPicture(16781835)[codec(pgssub) language(English) opcode(extract)]
              2m 50.98s: info: stream output SubPicture(16781835)[codec(xsub) language(English)]
              2m 50.98s: info: stream input@ SubPicture(16781837)[codec(pgssub) language(French) opcode(extract)]
              2m 50.98s: info: stream output SubPicture(16781837)[codec(xsub) language(French)]
              2m 50.98s: info: SubMode(Extract) -- Display Only forced Subtitle(true)
              2m 50.98s: UILog:MsgWork:WorkStatus_Start
              2m 50.99s: info: enable multi-thread software decoder, thread count = 4
              2m 52.74s: info: h264_encode: encode param profile(2) level(41) bitrate(9207) crf(-1)
              2m 52.76s: info: processing source(00000.m2ts)
              112m 06.54s: info: processing source(00072.m2ts)
              138m 36.26s: info: enable multi-thread software decoder, thread count = 4
              138m 36.27s: info: h264_encode: encode param profile(2) level(41) bitrate(9207) crf(-1)
              138m 43.09s: info: processing source(00000.m2ts)
              142m 46.27s: info: processing source(00014.m2ts)
              144m 23.26s: info: processing source(00015.m2ts)
              146m 11.33s: info: processing source(00016.m2ts)
              150m 56.02s: info: processing source(00017.m2ts)
              152m 28.38s: info: processing source(00018.m2ts)
              154m 39.99s: info: processing source(00019.m2ts)
              157m 17.06s: info: processing source(00048.m2ts)
              158m 10.90s: info: processing source(00049.m2ts)
              158m 49.91s: info: processing source(00050.m2ts)
              159m 47.92s: info: processing source(00051.m2ts)
              162m 56.54s: info: processing source(00052.m2ts)
              164m 05.76s: info: Find Forced Subtitle Stream : PID(4608), Language(English), First Time At(timestamp: 00:26:12:608)
              166m 05.32s: info: processing source(00053.m2ts)
              247m 53.12s: info: processing source(00072.m2ts)
              273m 58.53s: ------------------ convert work finished ------------------
              273m 59.66s: UILog:MsgWork:current work finish : 3
              273m 59.66s: UILog:Run Work to end.
              274m 13.59s: Exit process: stop running.
              274m 13.70s: Exit process: preview pfn_releaseplayer end
              274m 13.76s: Exit process: preview pfn_deinit end
              274m 13.98s: Exit process: preview FreeLibrary end
                pivert
                It can not fixed your issue, like 90312 said?
                I will test audio this week, hope can reproduce it and fixed it soon.
                DVDFab log default location:
                DVDFab Player 5:
                  audio
                  I do all my MKV with audiocopy so no AAC or AC3
                  now the video on output file goes twice the speed and the duration of the movie is 45 mn vs 1h30
                  The original BD is 50p, and there is no other choice for me than "frame rate identical to source"
