Hello, there - apologies if this is something simple that I'm just not able to figure out, but I can't seem to get DVDFab to process an ISO image file into a new ISO image file without having to compress it.
For example, if I pick DVD5 as the destination size and the original ISO is large enough to require compression, then DVDFab will happily generate a new ISO file successfully. However, if I pick DVD9 in order to preserve full quality (or if the source ISO is small enough to not require compression for DVD5), then DVDFab displays this prompt:
"There is no need to copy Full Disc between ISO files without compression.
Do you want to continue?"
...and you can only click on "OK" but nothing happens.
So how can I get DVDFab to process a source ISO file into a new ISO file without having to compress?? Any help would be GREATLY appreciated - thanks in advance! =)
