Sound Problem Converter
    When converting some videos that the sound is very bad. It sounds like it was recorded in very heavy rain with blown out speakers.
    I went back and found that it started in x64 11.0.0.8 and continues in 11.0.1.0. Previous versions work fine. Same file and settings.
    Converting to General MKV but tried different formats with the same result.
    All the videos that have this problem say DTS/5.1. AAC/5.1 works fine.
    I have attached log files for both x64 11.0.0.7 and 11.0.0.8
    Hi Tim,
    Sorry for the trouble, we are working on this problem, will fix it as soon as possible.
      Any progress on this? The problem is still there in latest version. x64 11.0.1.2
        It's still been working on, we will keep you posted. Please kindly wait for update, thank you.
          UPDATE: it's fixed, please kindly wait for next build and try again. Thank you.
