Discovery+ audio bitrate issue
    That is, StreamFAB loads inferior audio bitrate. Manually when watching a mpd link, the audio is 64.0 kbps and 160 kbps, and streamFAB selects the worse. This problem is quite uncomfortable because the 64 kbps quality is not very good. It would be best if you could choose the audio. But at least so that it chooses the best quality.
    I use https://www.discoveryplus.com/fi
    Normally, it should pick the audio with the best audio. Please provide the StreamFab log file as well, we will check. Thanks.
      Hope this is the right file
        Thanks. I will have the developer check the logfile. If there is news or updates, I will let you know.
          Thanks for helping
