Re-enconding problem
    Hello,
    i would like to report a problem very big with re-encoding.
    I'm working on a virtual machine (no gpu, only cpu) and once streamfab downloaded and re-encoded the video, size is very big.
    As you can see from this image, dimension is around 10 gb and bitrate over 20 mb/s... ?
    I tried last week with another tvshow and nothing, same problem. Size is too big. Unfortunately due a problem with my connection, i have to works on my dedicated and i can't use any gpu.
    Regards
    Please wait for the coming version and then try again, thanks.
