v4.0.1.5 HBO Max Missing Right Scrolling arrow
    With version 4.0.1.5 I am not seeing a right arrow to scroll right with HBO Max. I can scroll with the arrow keys and when I do a left arrow will appear so I can use the mouse to scroll back to the left. But there is no right scrolling white arrow to use the mouse. Netflix and Amazon are fine.
    Jeff
    There hasn't been any responses to this. I am curious if others are seeing the same issue or if it is just me ?
    Thanks,
    Jeff
      Please check the image above, do you mean this one?
        Yes, that's it. I did some more testing and was able to get it to appear if I made the entire window larger.
        After resize:
        So it looks like it isn't a big issue afterall but a bit odd. I must have resized the StreamFab window smaller at some point.
        Jeff
          I will pass it to the developer first.
