Strange Recoding Process on Paravi and all other problems
    The recoding process on Paravi, Hulu Japan and U-Next has been really strange, I attached the log file, and here is the specific description:
    For Streamfab 5.0.1.1 Windows:
    1. The paravi has been failing recoding any video, which means any video can't be downloaded.
    2. The recoding process of Hulu Japan and U-Next have been extremely long. The file size is 3 times to 4 times the original file, and the bit rate is 3 times the original file, and the recoding process is at least 2 hours.
    For example, https://www.hulu.jp/watch/100098314, the original file size should be 300M, but the output after the weird recoding process is 1.02GB. The bitrate should be 4000Mb/s, but the bitrate of the output is 10000Mb/s.
    So, it is clear that the Streamfab is suppressing the original file to a bigger file with crazy size. Actually, it will not change the actual bitrate, because the limit of every stream flatform is limited, and the long recoding process is wasteful.
    For Streamfab 5.0.0.8 Mac:
    1. The Paravi is also enduring a long wasteful process that making a bigger file, just like I said above. But, the bitrate of the output after the long recoding process is extremely low. Although the video is 720P, the bitrate should be at least 2,000Mb/s, but the bitrate of the output is 500Mb/s, which is super low, and the actual bitrate on the Paravi website is absolutely higher than 500Mb/s.
    For example, https://www.paravi.jp/watch/82744, the output is 500Mb/s, so the recoding process is lowering the bitrate, not improving.
    2.The Streamfab 5.0.0.8 Mac can't detect any file and link in Hulu Japan and U-NEXT.
    I attached the log file below, could you please send my words to the IT staff? Thank you very much!
