HBO Max and StreamFab 5.0.1.5 not downloading
    After updating to StreamFab 5.0.1.5, tied several times to get Valley of Tears to download from HBO Max. No luck! I cleared my logs, my cache, then went into HBO Max, removed Valley of Tears, then re-added. All I could get was StreamFab to say it was downloading segment 1of 707 and just sit there. When trying to cancel download, it would say canceling and just sit there doing nothing. Had to end program via task manager. Attached is log and screen shot
    didn't upload log initially
      Follow-up....I went in to try again. Only thing I did different was change download from Hebrew audio with english subtitles to endglish audio and english subtitles. Now it downloads
        here is the log file after finally getting it to download so you may compare the two to find out what happened
          Okay, thank you for the update, the developer will check.
