Problem with Hulu JP downloader on MAC
    Hi, there are some problems when downloading Hulu Japan videos on Mac, and these problems are only in Mac, not in Windows.
    When I add a shows to download, the downloader added the task, but it never starts to download, only stuck on 0kb/s. Even if I can play the video, also the downloader found that.
    Also, when I using Option+Command+esc to close the downloader, after that, I can't re-open the downloader. I can only open it after I restart the whole system.
    Also, for Mac downloader, when I click the "VIP SERVICE" button, sometimes the software compulsively opens the Amazon webpage, and don't give me time to choose the stream service I want to open.
    Finally, the order system for Hulu JP is not correct, only on shows that has over 10 episodes, for example, https://www.hulu.jp/oyogenishikigoi The order of the episodes is in disorder.
    Please fix these bugs. Thank you very much!
    As a regular suggestion, please delete the two folders in the paths below to have a try first. I will meanwhile get the QA team to check if they can duplicate them.
    Finder/Documents/DVDFab/StreamFab/Temp
    Finder/Documents/DVDFab/StreamFab/log
    Please also provide a StreamFab log file to better check. Thanks.
