Trouble with TubiTV, using SteamFab x64 6118
    When I select TUBITv, I get this: Failed to load URL https://tubitv.com/ with error ERR_SSL_VERSION_OR_CIPHER_MISMATCH (-113).
    And if I right click on the URL StreamFab detects that, but when it attempts to download, I get the same error.
    Are you running Windows 7 or earlier?
    The staff is probably going to want a copy of your StreamFab.log so please include that as an attachment to them.
      Please try to clean the caches and temp files and then run it again.
      You can refer to the image to locate the path.
        Mona,
        With the greatest respect to you, I'd be extremely surprised if your suggestion will help in this case. https://tubitv.com/ uses TLS 1.2 only and the cyphers associated with it. If he has Windows set to TLS 1.1 or TLS 1.3 only, he would receive that error. The reason I mentioned Windows 7 is because it initially only came with TLS 1.0 and TLS 1.1. Those two have since been depreciated. A Microsoft update and some registry changes are needed to enable TLS 1.2 and TLS 1.3 on a Windows 7 computer. If you Google "Windows 7 TLS 1.2" you'll get a ton of articles on how to do it. I would recommend Microsoft's own instructions on how to enable TLS 1.2 at https://learn.microsoft.com/en-us/me...tls-1-2-client ​.
