scheduler does not work for RTL+ (Germany)
    Hello
    I'm runnint Streamfab demo v6.1.3.0.
    The download works well from RTL+, but the scheduler doesn't.
    After some minutes it says
    Failure checking for new episode(s), please download manually
    Logs are attached.
    Please kindly give us one example to better check, name the last one you are having a probelm with, thanks.
      The problem happens for every show on that platform.
      E.g.
      Alles was zählt
      Ex on the Beach
      Der König von Palma
      Best regards
        Hi, I got a reply from the developers, and for now, RTL+ Downloader does not support the Schedule feature. And I am afraid that there isn't much info regarding if or when it can be supported yet.
          thanks for clarifying!
