Max Fails to Load
    Max Max Fails to Load
    When I try to login to Max, I get the following Message: Failed to load URL https://www.max.com/ with error ERR_TOO_MANY_REDIRECTS (-310). I have tried it on Mac Versions 6.1.5.3 and went back and tried 6.1.4.7. I tried clearing my cache, but I still get the same message.
    Not a fix, but if I choose HBOMax, it will redirect to Max and work that way
      How did you clear the cache? Nothing pops out in your log as to what the problem might be.
      Are you in the US? Are you using a VPN?
