Below Deck Sailing - Audio Problem
    Peacock Below Deck Sailing - Audio Problem
    Tried downloading Below Deck Sailing Yacht S05E01 Today! Video worded great But Audio didn't download.
    It Downloaded En-ad, for both Tracks!!! Don't know what happen????
    please post the streamfab log files for better help.
      Format : Matroska
      Format version : Version 4
      File size : 2.37 GiB
      Duration : 42 min 44 s
      Overall bit rate : 7 945 kb/s
      Frame rate : 23.976 FPS
      Movie name : Ibiza, Baby!
      Description : Gary and Daisy try to work through resentments.
      Encoded date : 2024-10-09 15:08:36 UTC
      Writing application : mkvmerge v87.0 ('Black as the Sky') 64-bit
      Writing library : libebml v1.4.5 + libmatroska v1.7.1
      Video
      Format : AVC
      Format/Info : Advanced Video Codec
      Format profile : High@L4
      Format settings : CABAC / 3 Ref Frames
      Format settings, CABAC : Yes
      Format settings, Reference frames : 3 frames
      Codec ID : V_MPEG4/ISO/AVC
      Bit rate : 7 814 kb/s
      Width : 1 920 pixels
      Height : 1 080 pixels
      Display aspect ratio : 16:9
      Frame rate mode : Constant
      Frame rate : 23.976 (24000/1001) FPS
      Color space : YUV
      Chroma subsampling : 4:2:0
      Bit depth : 8 bits
      Scan type : Progressive
      Bits/(Pixel*Frame) : 0.157
      Stream size : 2.33 GiB (98%)
      Writing library : x264 core 164 r3108 31e19f9
      Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=34 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=48 / keyint_min=4 / scenecut=0 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=7814 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=11729 / vbv_bufsize=11729 / nal_hrd=none / filler=0 / ip_ratio=1.41 / aq=1:1.00
      Default : Yes
      Forced : No
      Color range : Limited
      Color primaries : BT.709
      Transfer characteristics : BT.709
      Matrix coefficients : BT.709
      Audio
      Format : AAC LC
      Format/Info : Advanced Audio Codec Low Complexity
      Codec ID : A_AAC-2
      Bit rate : 125 kb/s
      Channel(s) : 2 channels
      Channel layout : L R
      Sampling rate : 48.0 kHz
      Frame rate : 46.875 FPS (1024 SPF)
      Compression mode : Lossy
      Stream size : 38.3 MiB (2%)
      Title : English
      Language : English
      Default : Yes
      Forced : No
      Text #1
      Format : UTF-8
      Codec ID : S_TEXT/UTF8
      Codec ID/Info : UTF-8 Plain Text
      Duration : 42 min 34 s
      Bit rate : 110 b/s
      Frame rate : 0.427 FPS
      Count of elements : 1092
      Stream size : 34.5 KiB (0%)
      Title : Spanish
      Language : Spanish
      Default : Yes
      Forced : No
      Text #2
      Format : UTF-8
      Duration : 42 min 35 s
      Bit rate : 115 b/s
      Frame rate : 0.443 FPS
      Count of elements : 1133
      Stream size : 35.9 KiB (0%)
      Title : English
      Language : English
      Default : No
      Forced : No​
        This is actually a Peacock problem more than anything. Bravo shows that have been posted recently are affected (think Real Housewives, Below Deck, etc.). You have to select ONLY the second audio stream and it will work. If you download both audio streams, they will both be Audio Description. Hopefully SF can fix this, but until then, the workaround is to select only the second stream.
          I check and was able to Find a Fix! Buy un-Checking the First Auto Track and downloading only the Second track!
