It seems like it is taking forever to download a TV series. It pauses a couple of minutes if at all and than downloads the next episode. I also got the error "Due to the upgraded DRM encryption, videos on this website can only be downloaded in 720p as of now." It looks like it is downloading, but nothing is being downloaded.. Guess I will have to wait and see.
Problems with MAX??
I can confirm a delay in the 2nd analysis (before dl).Originally posted by beric3236 View PostIt pauses a couple of minutes if at all and than downloads the next episode.
> I also got the error "Due to the upgraded DRM encryption ..
It's not really an error, only an info (see pics here)
Like Disney the client (your local SF) can only get a key to decrypt max 720p.
So SF checks the SF server to see if the key for decrypting 1080p is known ..
.. this is also a reason why the analysis takes longer (as other providers)
Never seen with Max .. so try to rename your cache (if SF closed) - like here
If this don't work for you rename your StreamFab.log (if SF closed)
try once and then post (attach) you new log
I have also seen your problem a few times.Originally posted by beric3236 View PostSpoke to soon. It came back. 5min later it showed downloading but nothing was. Here are the logs. Thanks.
temporary solution here has been to pause the download and start it again.
The problem then is that you have to constantly monitor that analysis starts if you are going to download a lot.
