SF does not probe-down audio in "correct" order
    Disney+ SF does not probe-down audio in "correct" order
    Encountered this scenario: The first (and majority) of a series is available in ec-3 5.1 but one episode is only ec-3 2.0, and instead of downloading ec-3 stereo, SF downloads AAC.
    Series in question: Alias (S01E17 is the oddity)
    and even if you select the episode to be analysed manually, even though the analysis window shows ec-3 stereo, SF still downloads AAC...
    Yes, if selected EAC3 5.1 is not available ..
    .. looks like only AAC is fallback - not EAC3 2.0
    But after analyzing Alias.s01e01 and select s01e17 I get EAC3 5.1 German ..
    .. so I retried same with english and (of course) I can confirm:
    Code:
    [Info]: [Analyze Dlg]:  "Record add to queue -- Audio:{\"bandwidth\":0,\"channel\":6,\"codecs\":\"eac-3"
    [Info]: "[DownloadDisney]" Match audio/subtitle success
    [Info]: audio info lang:  en  codecs:  eac-3  bandwidth:  0  channel:  2
    [Info]: Remux show audiocodec: "EAC3"
    [Info]: format : "AAC LC"
    Is actually just as much nonsense as changing the selected video codec
    just because the bitrate is different - like here
    btw: Sometimes the display is really funny (VIP Setting H265 - SDR)
      great, now I have to go and change my check script to check for random codec switching
