Subtitle error Some Problem
    I use UDH copy Main ver 10.0.7.6 add external Subtitle
    Player Bluray External Subtitle error Not display only display from star, if next chapter will off display.
    Im checking by bdsup2sub found some error .
    ( file attach )
    This error revert if you use Ripper Just Externall Subtitle display all file Subtitle internal error not display.
    Please checking and fix have problem.
    Thanks you
    Hello,
    Sorry, cannot understand your problem well. And the screenshots are too small to check clearly.
    Do you mean that the external subtitle can display correctly but disappear on next chapter during playback?
    Where did you playback the output file? Standalone player or software player?
    Regards,
    mona
      External Subtile Just only display if you play select firstime. Next chapter or fastview lost subtitle let long time see again.
        Hello,
        What player did you use for playback?
        Please send me a copy of the external subtitle, so that we can test on our side.
        Also, please post dvdfab_internal.log file.
        Regards,
        mona
          I use DVDFab 5 Player
          I make Lucy fims add subttitle Vietnam chose English Character set GB 18030
          I send file sub and Log
          Thanks you
            Thanks you
            We will check it out and get back to you ASAP.
            Regards,
            mona
              hi huyhoang72,
              1. from the log , your are using m2ts converter (M2TS.4K.H265.10bit) add external sub.
              If play result m2ts, the sub is can show use MPC-HC / DVDFab Player 5.
              2. if you want uhd , use mainmovie add external sub. The ripper/ converter m2ts is different with m2ts in BD STREAM folder.
              3. for remux uhd, add or remove sub. if your want deal many uhd / bd, see DVDFab DIY, https://www.dvdfab.cn/dvdfab-diy.htm.
              yours,
                Thanks for Reply
                But I can't to buy sofware.
                How i can buy?
                  Thanks for Reply
                  How i can buy?
                  Please send me an email about DIY purchase, we will send you the details.
                  Regards,
                  mona
                    Until error Subtitle not screen display Version 10.0.7.7 x64
                    1. Use DVDfab UHD to 25gb Maintitle not error Subtitle display
                    2. Use DVDfab UHD 50gb Maintile Error subtitle not display.
                    I use file Lucy subtitle SRT., i send File DVD log.
                      I Think. It's same problem like this https://forum.dvdfab.cn/forum/softwa...btitle-problem .
                      and dvdfab already fixed. But then I checked with only compress file to UHD 25G.
                      Now I tested with UHD 50G.
                      1. Soure file less than 50G when you choose UHD 50G will not be compressed. Subtitle will display on TV delay about 30 sec or more when you press skip next chapter. Same promblem when source file less than 25G when you choose UHD 25G. ==> not working properly.
                      It's same problem both of Zappiti 4K HDR Mini and LG UP970.
                      2. Source file more than 50G when you choose UHD 50G will be compressed. Subtitle will display on TV normally when you press skip next chapter. ==> it's working properly.
                        I'm test by DvdFab 5.0.0.4 before to burn disc. Discovery some problems above.
