Dolby Vision problem in UHDcreator
    Source "Power Rangers 2017 2160p UHD Blu-ray HEVC TrueHD 7.1-TERMiNAL"
    - Make MKV with Dolby Vision Track by MKVtoolnix
    - Take MKV to UHDcreator Conversion 25G and UHDcreator Passthrough
    - UHDcreator Conversion 25G get OUTPUT UHDBD 32G (1)
    - Take UHDBD 32G to UHDcopy 25G (2)
    - Take UHDcreator Passthrough to UHDcopy 25G (3)
    - Take (1) , (2) , (3) burn To discs And Play on LG UP970
    All Discs get this problem (See Pictures)
    We will check the problem ASAP, thanks!
      Any Update?
        Any Update?
          Hi Gantz,
          We've talked about the problem you reported via PM. About this problem, the source m2ts file doesn't has Dolby Vision issue with UHD Creator, the problem is with the mkv file created by MKVtoolnix, we suggest that you contact the support at MKVtoolnix for some info.
          Regards,
          Mona
